1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn 4-35 does not compile on Windows 10 (VS 2019)
To: "Gofron, Kazimierz" <[email protected]>
Date: Sat, 18 May 2019 12:25:20 +0000
The problem was that the iocsh arguments were being passed by taking the address of an expression,  rather than a variable.  This is not allowed in VS2010.
I have fixed the problem and pushed to master on Github.
Sent: Friday, May 17, 2019 8:41 PM
To: Mark Rivers
Cc: [email protected]; Zimoch Dirk (PSI)
Subject: RE: asyn 4-35 does not compile on Windows 10 (VS 2019)
Asyn 4.35 does not compile on Visual Studio 2010. {I had too many windows opened}
But, it does compile on the Visual Studio 2019 CE, v16.0.4
-K
-----Original Message-----
Sent: Friday, 17 May 2019 3:34 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected]; Zimoch Dirk (PSI) <[email protected]>
It compiles fine on VS2015 (and VS2017 I believe)
Sent from my iPhone
On May 17, 2019, at 3:15 PM, Gofron, Kazimierz <[email protected]<mailto:[email protected]>> wrote:
I am having problems compiling asyn 4-35 (and current version of master) on Windows 10 with Visual Studio 2019 Community Edition. Problem is specific to windows since asyn-4-35 compiles on debian 7/8/9 and ubuntu 18.
C:\epics\support\asyn>make
make[1]: Entering directory 'C:/epics/support/asyn/asyn'
perl -CSD C:/epics/base/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'C:/epics/support/asyn/asyn/O.windows-x64'
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/epics/support/ipac/include   -IC:/epics/support/seq/include -IC:/epics/base/include/compiler/msvc -IC:/epics/base/include/os/WIN32 -IC:/epics/base/include        -c ../../asyn/drvAsynSerial/drvAsynIPPort.c
drvAsynIPPort.c
c:\epics\support\asyn\asyn\drvasynserial\drvasynipport.c(462) : warning C4267: 'function' : conversion from 'size_t' to 'int', possible loss of data .....
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/epics/support/ipac/include   -IC:/epics/support/seq/include -IC:/epics/base/include/compiler/msvc -IC:/epics/base/include/os/WIN32 -IC:/epics/base/include        -c ../../asyn/miscellaneous/asynInterposeDelay.c
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(216) : error C2059: syntax error : '{'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(220) : error C2059: syntax error : '}'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(229) : fatal error C1903: unable to recover from previous error(s); stopping compilation
make[2]: *** [C:/epics/base/configure/RULES_BUILD:235: asynInterposeDelay.obj] Error 2
make[2]: Leaving directory 'C:/epics/support/asyn/asyn/O.windows-x64'
make[1]: *** [C:/epics/base/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[1]: Leaving directory 'C:/epics/support/asyn/asyn'
make: *** [C:/epics/base/configure/RULES_DIRS:84: asyn.install] Error 2 ==========================================================================================
There is a similar error in asyninterposeecho.c, when compiling with -sj> make -sj
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(190) : error C2059: syntax error : '{'
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(193) : error C2059: syntax error : '}'
ParamValWrongType.cpp
c:\epics\support\asyn\asyn\miscellaneous\asyninterposeecho.c(202) : fatal error C1903: unable to recover from previous error(s); stopping compilation
c:\epics\support\asyn\asyn\miscellaneous\asyninterposedelay.c(229) : fatal error C1903: unable to recover from previous error(s); stopping compilation paramVal.cpp
make[2]: *** [C:/epics/base/configure/RULES_BUILD:234: asynInterposeEcho.obj] Error 2
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [C:/epics/base/configure/RULES_BUILD:234: asynInterposeDelay.obj] Error 2 ParamValValueNotChanged.cpp asynPortDriver.cpp asynPortClient.cpp devAsynOctet.c
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(326) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32', possible loss of data
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(746) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32', possible loss of data
c:\epics\support\asyn\asyn\devepics\devasynoctet.c(751) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(136) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(144) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(157) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\epics\support\asyn\asyn\asynportdriver\asynportdriver.cpp(796) : warning C4267: 'argument' : conversion from 'size_t' to 'int', possible loss of data
The source lines indicate the Visual Studio does not interpret 2nd set of "{"
/* register asynInterposeEcho*/
static const iocshFuncDef asynInterposeEchoFuncDef =
    {"asynInterposeEcho", 2, (const iocshArg *[]) {
    &(iocshArg) { "portName", iocshArgString },
    &(iocshArg) {  "addr", iocshArgInt },
/* register asynInterposeDelay*/
static const iocshFuncDef asynInterposeDelayFuncDef =
    {"asynInterposeDelay", 3, (const iocshArg *[]) {
    &(iocshArg) {  "delay(sec)", iocshArgDouble },
Cheers,
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]<mailto:[email protected]>
(w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
asyn 4-35 does not compile on Windows 10 (VS 2019) Gofron, Kazimierz via Tech-talk
Re: asyn 4-35 does not compile on Windows 10 (VS 2019) Mark Rivers via Tech-talk
RE: asyn 4-35 does not compile on Windows 10 (VS 2019) Gofron, Kazimierz via Tech-talk
Prev: Controls Engineer Position at NSLS-II (Brookhaven National Lab) Tian, Yuke via Tech-talk
Next: Phoebus on Raspberry Pi 3b+ 김재우 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn 4-35 does not compile on Windows 10 (VS 2019) Gofron, Kazimierz via Tech-talk
Next: Controls Engineer Position at NSLS-II (Brookhaven National Lab) Tian, Yuke via Tech-talk
ANJ, 20 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
