1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Building MEDM on linux rhel7
From: "Madden, Timothy J. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Date: Mon, 20 May 2019 19:55:48 +0000
Ahhhh. Thanks Mark for the tip.
Tim
Sent: Monday, May 20, 2019 2:53:07 PM
To: Madden, Timothy J.
Cc: [email protected]
Note that in your gcc command -I is followed immediately by -MM, rather than by an include directory. This suggests a problem with configure/RELEASE, since it should probably be the location of EPICS base.
Sent from my iPhone
On May 20, 2019, at 1:16 PM, Madden, Timothy J. via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
I am building medm on rhel7. Medm is already installed, but when typing into text input fields, it will not accept
entry. caput to the PV works. Strange. I assume that there are mismatched libraries on the OS and whatever
medm was built with. I have seen this very problem on windows boxes.
So when building, I yum installed all the packeages from the medm website, https://epics.anl.gov/extensions/medm/index.php
I am using this linux:
Linux csi357421.aps.anl.gov<http://csi357421.aps.anl.gov> 3.10.0-957.10.1.el7.x86_64 #1 SMP Thu Feb 7 07:12:53 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
I am using base 3 15 6
I get these errors during make, when trying to make printutils. See below. Any ideas?
Tim Madden
bash-4.2$
bash-4.2$ make
make -C ./printUtils install
make[1]: Entering directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include     -I    -MM -MF xwd2ps.d  ../xwd2ps.c
cc1: error: to generate dependencies you must specify either -M or -MM
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include     -I    -MM -MF xwd.d  ../xwd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include     -I    -MM -MF utilPrint.d  ../utilPrint.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include     -I    -MM -MF ps_utils.d  ../ps_utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include     -I    -MM -MF pUtils.d  ../pUtils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include     -I    -MM -MF getopt.d  ../getopt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include     -I    -c ../getopt.c
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
collect2: error: ld returned 1 exit status
make[2]: *** [getopt.o] Error 1
make[2]: Leaving directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/RFINJ/swWork/epics/base-3.15.6/ext/medm-MEDM3_1_11/printUtils'
make: *** [printUtils.install] Error 2
Building MEDM on linux rhel7 Madden, Timothy J. via Tech-talk
Re: Building MEDM on linux rhel7 Mark Rivers via Tech-talk
Prev: Re: Building MEDM on linux rhel7 Mark Rivers via Tech-talk
Next: Re: Request for Response of Projects that Use EPICS Tlusty, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: A new member questions Andrew Johnson via Tech-talk
ANJ, 21 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
