1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Receiving duplicate monitor values using CA PV Gateway
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Mon, 3 Jun 2019 22:31:53 +0000
Hi William,
On 6/3/19 12:13 PM, Layne (US), William C via Tech-talk wrote:
Here is the output for a few seconds.
Thanks; so the first monitor update is getting duplicated when it's coming from the CA gateway, and from Jure Varlec's post it sounds like this behaviour only occurs when running the gateway in its -no-cache mode. This confirms that the problem is internal to the gateway.
We don't have a dedicated maintainer for the gateway, and Ralph Lange who is nominally responsible for it doesn't have much if any time to work on it. Nobody is going to have any objections to your looking into the internals of the code and proposing a fix if you feel so inclined. In any case Ralph is busy all this week organizing the EPICS Collaboration Meeting that is going on at ITER in France.
If you are developing your own client software it should be relatively straightforward to detect and discard these duplications by comparing the monitor events timestamps, as long as you're using one of the data types which includes that information.
- Andrew
Complexity comes for free, Simplicity you have to work for.
RE: Receiving duplicate monitor values using CA PV Gateway Layne (US), William C via Tech-talk
Re: Receiving duplicate monitor values using CA PV Gateway Layne (US), William C via Tech-talk
Prev: Re: Camonitor with client dictated update rate Hinko Kocevar via Tech-talk
Next: RE: Receiving duplicate monitor values using CA PV Gateway Layne (US), William C via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Receiving duplicate monitor values using CA PV Gateway Layne (US), William C via Tech-talk
ANJ, 03 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
