1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with AreaDetector and Eiger External Series?
From: "Zhang, Zhan via Tech-talk" <[email protected]>
To: Jesse Hopkins <[email protected]>
Date: Wed, 26 Jun 2019 15:52:04 +0000
Hi Jesse,
                I don’t have an Eiger but for the Andor3 we use, that’s the same behavior I observe.  And that’s what I expected, too.  The ‘Acquiring’ is on means it is ‘armed’ and ready to response to any trigger.  All I need to do is send another set of triggers (or TTL’s in my case).  My detector is always in ‘Acquiring’ mode unless I need to change parameters.  I don’t have trouble to start another series of exposure—I don’t need to hit ‘Acquire’ button any more, just sending the trigger.  Was that what your Eiger failed?
Zhan
Zhan Zhang, Ph. D.
Argonne National Laboratory
X-ray Science Division, 438-D005
9700 S. Cass Ave.
Argonne, IL 60439
Tel : 630-252-0863
Email: [email protected]
From: [email protected] <[email protected]> On Behalf Of Jesse Hopkins via Tech-talk
Sent: Wednesday, June 26, 2019 10:07 AM
To: [email protected]
Subject: Problem with AreaDetector and Eiger External Series?
We have an Eiger X 500K. I'm using AreaDetector to control it, and encountering a strange issue with the External Series trigger mode. I set the trigger mode to external series, and 'Start' collection. If I then send an external trigger, the series collects as expected. I can watch NumImagesCounter_RBV increment, and it reports the right number of images collected. However, after all the images are collected, Acquire stays 'Collecting'. In order to take another series I have to first click the 'Stop' button. Additionally, the StatusMessage_RBV stays as 'Waiting for external trigger' until I click the 'Stop' button.
This is in contrast to the Internal Series behavior, where at the end of a series Acquire goes to 'Done' as I would expect.
I don't know if this is a bug, or expected behavior based on a setting I haven't found somewhere. Insight would be appreciated. I did look through the release notes for ADCore 3.5 and 3.6 and the Eiger driver 2-7 and didn't see anything that indicated this was fixed (if it is a bug).
ADCore version: 3.4.0
Driver version: 2-6 (though the GUI is reporting 2-5?)
Eiger firmware version: 1.6.6
SIMPLON API version: 1.6.0
GUI: MEDM
Series settings (for testing): Images: 10, Triggers: 1, Exp time: 2 s, Exp Period: 2.1 s
Thanks.
- Jesse
Jesse Hopkins, PhD
Beamline Scientist
BioCAT, Sector 18
Advanced Photon Source
Re: Problem with AreaDetector and Eiger External Series? Jesse Hopkins via Tech-talk
Prev: Problem with AreaDetector and Eiger External Series? Jesse Hopkins via Tech-talk
Next: Re: Problem with AreaDetector and Eiger External Series? Jesse Hopkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
