1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: updating ADAndor from RHEL6 to RHEL7
From: Hinko Kocevar via Tech-talk <[email protected]>
To: "Pearson, Matthew R." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 9 Jul 2019 18:30:45 +0000
Hi Matt,
we at ESS have been using 2.102 (IIRC I added that one to the ADAndor) with USB2.0 based Newton, iDus and Luca cameras for some time now. Our Linux flavor is CentOS7 which might be similar to RHEL7.
I did have quite some trouble getting the cameras to be detected by the Andor SDK, after the IOC would be killed. The Andor SDK would leave behind a shm object that would not get removed by the SDK in that case which resulted in subsequent IOC restarts to fail to detect the camera (until Linux OS would be rebooted). I did find a way to solve the issue by removing the offending lingering shm object using ipcrm tool, prior to starting on IOC.
I can provide more details about the CentOS7 kernel and system config if you need.
Cheers,
//hinko
From: [email protected] <[email protected]> on behalf of Pearson, Matthew R. via Tech-talk <[email protected]>
Sent: Tuesday, July 9, 2019 12:52:58 AM
To: [email protected] Talk
Subject: updating ADAndor from RHEL6 to RHEL7
Has anyone experience updating the ADAndor support from RHEL6 to RHEL7?
We have an Andor iKon-M (USB2.0 based), that we used with ADAndor on RHEL6 using SDK 2 version 2.93 (locally installed, not using the version distributed with ADAndor).
The same SDK version doesn’t seem to work on RHEL7. I can send details if anyone is interested. It may just be too old though.
There are two more modern SDK versions currently distributed with ADAndor (at least, the shared libraries). Is anyone using either of these versions (2.99 and 2.102) on RHEL7?
Cheers,
Matt
Data Acquisition and Controls Engineer
Spallation Neutron Source
Oak Ridge National Lab
Re: [EXTERNAL] updating ADAndor from RHEL6 to RHEL7 Pearson, Matthew R. via Tech-talk
Prev: RE: updating ADAndor from RHEL6 to RHEL7 tom.cobb--- via Tech-talk
Next: Empty string as SNL macro Hovanes Egiyan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] updating ADAndor from RHEL6 to RHEL7 Lutes, Troy E. via Tech-talk
Next: Re: [EXTERNAL] updating ADAndor from RHEL6 to RHEL7 Pearson, Matthew R. via Tech-talk
ANJ, 10 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
