Hi all, very infrequently my scan hangs because ADAndor acquire state stays "collecting" after the acquisition completed successfully and detector state returns to "idle" and detector status is "IDLE, waiting on instruction". Screen shot of the medm screen below. The IOC output doesn't have any message indicating there is a problem. If i click "stop" the Acquire state goes to "Done" however the scan does not continue. If i click "start" the detector responds normally, acquires one image and everything looks good. At the conclusion of the image that I started manually the scan will continue. I don't know how to reproduce this on demand. It's happening once every few thousands of images. Any tips on how to troubleshoot it next time it happens would be greatly appreciated. ADCore: 3.3.1 Driver: 2.8.0 SDK: 2.102 Thanks, David -- Best regards, David Vine (925) 326 7503
This e-mail and any attachments are provided for the sole use of the intended recipient(s), and may contain information that is confidential, privileged, proprietary or otherwise protected by law. If you are not the intended recipient of this message, you are not authorized to read, print, retain, copy, forward or otherwise disseminate this message or any part of it. If you have received this e-mail in error, please notify the sender immediately by reply e-mail and delete the original message from your mail system. Thank you. Attachment:
| ANJ, 10 Jul 2019 |
Home
News
About
Talk
Base
Modules
Extensions
