1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base labels and series descriptions at epics.anl.gov
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 23 Jul 2019 13:21:17 -0500
On 07/22, Johnson, Andrew N. wrote:
> Some of these differences are deliberate, some may be because I missed
> something when updating the site...
Hi, Andrew!
Thanks for your reply!  I have just a few more questions below.
BTW, the quoting is messed up for the text/plain part of your email:
none of the quoted text is prefixed with a greater-than sign ('>') or
other marking string.  I've fixed it in this reply.
>> On 7/22/19 2:40 PM, J. Lewis Muir via Tech-talk wrote:
>> At the EPICS Base page
>>   https://epics.anl.gov/base/index.php
>> there's an EPICS Base series list:
>>   * EPICS 7.0 (2017-present) – current release series
>>   * Release 3.16 (2016-2018) – closed
>>   * Release 3.15 (2014-present) – stable release series
>>   * Release 3.14 (2002-2018) – closed
>>   * Release 3.13 (1996-2003) – closed, deep-frozen
>>   * Release 3.12 (1995) – closed, historic
>>   * Release 3.11 (1991-1994) – closed, fossilized
>> Why is the EPICS Base 7.0 series labeled "EPICS 7.0" when the others
>> are labeled "Release 3.x"?  It seems to me that it should be labeled
>> "Release 7.0".
> Because the community decided (at the SNS collaboration meeting IIRC)
> they wanted to call the result of merging Base 3.x with the V4 (now PVA)
> modules "EPICS 7" [and if you insert an R or V in there you lose the
> ability to pronounce it "epics heaven"]. Those of us with OCD tendencies
> (or CDO to be alphabetically pedantic) just have to get used to the
> change.
I understood that the major version number jumped from 3 to 7 (because 3
+ 4 = 7), but I didn't know about a name change.  This is probably where
I'm confused.
What is the name of the 7.0 release series?  I thought it was "EPICS
Base 7.0".
What is the name of the 3.15 release series?  I thought it was "EPICS
Base 3.15".
What is being listed in that list?  I thought it was basically "Release
[series] X.Y" where the word "series" is implied and omitted.  I thought
the list labeling was leaving out the "EPICS Base" part of the name and
just saying it's "Release [series] X.Y".  If all of that is true (which
it's probably not), then I was suggesting that the 7.0 release series
name of "EPICS Base 7.0" would translate to "Release 7.0" which would
match the existing pattern of "Release [series] X.Y".
Lewis
Re: EPICS Base labels and series descriptions at epics.anl.gov Johnson, Andrew N. via Tech-talk
EPICS Base labels and series descriptions at epics.anl.gov J. Lewis Muir via Tech-talk
Prev: Re: EPICS Base bin/<arch>/ca{get,info,monitor,put}.pl scripts Johnson, Andrew N. via Tech-talk
Next: Re: EPICS Base labels and series descriptions at epics.anl.gov Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base labels and series descriptions at epics.anl.gov Johnson, Andrew N. via Tech-talk
ANJ, 23 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
