1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: New releases of mca, measComp, and modbus modules
To: "'[email protected]'" <[email protected]>
Date: Fri, 9 Aug 2019 21:03:28 +0000
Folks,
New releases of the synApps mca, measComp, and modbus modules are now available.
mca R7-8
  * Added support for a new InputPolarity record for the SIS3820. This allows selecting the polarity of the control inputs.
  * Added OPI autoconvert files for edm, CSS BOY, and caQtDM.
Home page:
http://cars.uchicago.edu/software/epics/mca.html
Documentation:
http://cars.uchicago.edu/software/epics/mcaDoc.html
Release notes:
http://cars.uchicago.edu/software/epics/mcaReleaseNotes.html
Github source repository:
https://github.com/epics-modules/mca
measComp R2-3
  * Improved behavior for E-1608 when there are brief network outages. If the waveform digitizer was running when the outage occurred it would stop and not restart when the network recovered.
    This has been fixed, and tested with the E-1608 on both Linux and Windows.
  * Added Makefile to produce autoconverted OPI files from medm to edm, CSS/BOY, and caQtDM. Added/updated the autoconverted files for these.
Home page:
http://cars.uchicago.edu/software/epics/measComp.html
Documentation:
http://cars.uchicago.edu/software/epics/measCompDoc.html
Release notes:
http://cars.uchicago.edu/software/epics/measCompReleaseNotes.html
https://github.com/epics-modules/measComp
modbus R3-0
  * This is a major rewrite of the driver, changing from C to C++ inheriting from asynPortDriver.
     The major reason for the change is to be able to invoke the class methods such as drvModbusAsyn::doModbusIO() from other drivers.
     This allows drivers that communicate with Modbus devices to call methods to perform the Modbus I/O directly, which was not possible with the previous C API.
 * The new driver should be completely backwards compatible with previous versions, so no changes to IOC startup scripts or OPI displays are required.
  * A new example program, testClient.cpp, has been added. This program demonstrates how to instantiate a drvModbusAsyn object and use it to perform Modbus I/O to an external device.
     This example is a pure C++ application running without an IOC. The same code could be used in a driver in an IOC.
Home page:
http://cars.uchicago.edu/software/epics/modbus.html
Documentation:
http://cars.uchicago.edu/software/epics/modbusDoc.html
Release notes:
http://cars.uchicago.edu/software/epics/modbusReleaseNotes.html
https://github.com/epics-modules/modbus
Cheers,
Prev: Unhelpful MSI error message and behaviour Eric Norum via Tech-talk
Next: New releases of dxp, dxpSITORO, and quadEM Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
