1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Phoebus Radiobutton cannot set mbbi record
From: Florian Feldbauer via Tech-talk <[email protected]>
Date: Mon, 12 Aug 2019 08:40:05 +0200
Hey all,
in a test setup I'm currently using base 7.0.2.2 and Phoebus (commit ff6d0dc4).
Now I have some bi and mbbi records like this:
record( mbbi, "PANDA:LMD:MUPIX:TELESCOPE:L$(LAYER):ToT" ) {
  field( DTYP, "Raw Soft Channel")
  field( ZRST, "ToT" )
  field( ONST, "2Thres" )
  field( TWST, "Ramp")
  field( ZRVL, "0" )
  field( ONVL, "2" )
  field( TWVL, "1" )
record( bi, "PANDA:LMD:MUPIX:TELESCOPE:L$(LAYER):bandgap1" ) {
  field( ZNAM, "disabled" )
  field( ONAM, "active" )
For the mbbi record I'm using the Radiobutton widget and for the bi the checkbox widget.
I tried CA as well as PVaccess (PV name "PANDA:..." and "pva://PANDA:...)
In both cases I cannot change the value of the records. The checkbox only works if I explicitly append ".RVAL" to the PV name. The Radiobutton does nothing. Is this behavior expected or am I doing something wrong?
Best regards,
Florian
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Prev: New releases of dxp, dxpSITORO, and quadEM Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] procServ v2.8.0 available Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
ANJ, 12 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
