1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: New versions of areaDetector modules ADGenICam, ADAravis, ADSpinnaker released
To: "'[email protected]'" <[email protected]>
Date: Mon, 12 Aug 2019 23:36:51 +0000
New releases of the following areaDetector modules are now available.
ADGenICam R1-0
ADAravis R1-0
ADSpinnaker R2-0
ADGenICam is a new EPICS areaDetector driver for GenICam cameras. It is a base class that actual drivers inherit from. These actual drivers implement the GenICam standard in vendor-specific SDKs.
https://areadetector.github.io/master/ADGenICam/ADGenICam.html
The following drivers currently derive from this base class:
ADAravis which supports any GigE, 10GigE, or USB-3 GenICam camera on Linux. It is based on aravis.  It is intended to replace the existing areaDetector aravisGigE driver.
https://areadetector.github.io/master/ADAravis/ADAravis.html
ADSpinnaker which supports GigE, 10GigE, and USB-3 GenICam cameras from FLIR/Point Grey on Linux and Windows. It uses the FLIR/Point Grey Spinnaker SDK.  It is intended to replace the existing areaDetector ADPointGrey driver.
https://areadetector.github.io/master/ADSpinnaker/ADSpinnaker.html
ADVimba which supports GigE, 10GigE, and USB-3 GenICam cameras from AVT/Prosilica on Linux and Windows. It uses the Allied Vision's Vimba SDK.  It is intended to replace the existing areaDetector ADProsilica driver.  https://github.com/areaDetector/ADVimba
This driver is not yet ready to be released and does yet have documentation.
Prev: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] procServ v2.8.0 available Vodopivec, Klemen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: motor R7-1 released Peterson, Kevin M. via Tech-talk
ANJ, 13 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
