1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: mbboDirect record setup
From: Pontius Pontiac via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 13 Aug 2019 16:45:21 -0700
While setting up an mbboDirect record with an Acromag XT1111 Binary I/O module, I observe the behavior that only the LSB of my 6-bit mbboDirect bit bank is being changed when the EPICS value is changed. Is modbus function "6" the appropriate one to use for the mbboDirect data type? The drvModbusAsynConfigure instruction I am using is:
drvModbusAsynConfigure("C1ISCAUX_BIO02","c1iscaux_bio02",0,6,0,4,0,1,"Acromag")
and the EPICS record itself is set up as:
grecord(mbboDirect,"C1:LSC-CM_REFL1_BITS")
    field(DESC,"REFL1 gain bits")
    field(DTYP,"asynUInt32Digital")
    field(OUT,"@asynMask(C1ISCAUX_BIO02 0 0x1)")
    field(NOBT,"6")
    field(OMSL,"closed_loop")
    field(DOL,"C1:LSC-CM_REFL1_SET")
    field(PINI,"YES")
I'm also wondering if it is possible to have mbboDirect bits that are grouped together from two separate hardware Binary I/O PLCs?
thanks,
gautam
Prev: motor R7-1 released Peterson, Kevin M. via Tech-talk
Next: Re: [EXTERNAL] procServ v2.8.0 available Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: FW: mbboDirect record setup Mark Rivers via Tech-talk
ANJ, 15 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
