1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: connection timeout between ioc and logstash
To: tech-talk <[email protected]>
Date: Thu, 15 Aug 2019 11:11:58 +0800 (GMT+08:00)
Hi all,
  We are testing for using logstash to replace iocLogServer. We found that it will lose connection between the ioc and logstash if none of PV has been written more than an hour(not very accuracy). If writting a PV again, it will establish the connection again, but the caPutLog message of this time will not be sent to logstash. It prompted that in IOC terminal:
log client: lost contact with log server at "10.1.236.30:7011" because "Connection timed out"
log client: connected to log server at "10.1.236.30:7011"
from then on, it will work fine if the interval time of writting PV was not very long.So how can keep the connection all the time without timeout. It seems that using iocLogServer will not lose connection.
Any advice or suggestion will be appreciated.
Xuan
Re: connection timeout between ioc and logstash J. Lewis Muir via Tech-talk
Prev: Re: Fwd: Re: Fwd: cross-compiling (kind of) with Buildroot Hill, Bruce via Tech-talk
Next: Re: Pointer corruption on Windows Koennecke Mark (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: FW: mbboDirect record setup Mark Rivers via Tech-talk
Next: Re: connection timeout between ioc and logstash J. Lewis Muir via Tech-talk
ANJ, 15 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
