1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is anyone building AreaDetector with Sumo?
To: "Johnson, Andrew N." <[email protected]>, Jeong Han Lee <[email protected]>
Date: Thu, 22 Aug 2019 18:04:27 +0000
Jeong wrote:
       This is not true, and the following is the correct one.
<pre>
       *  EPICS Base -> asyn -> ADCore <- ADSupport
                                V
          Vendor Lib -> ADPointGrey -> FLIR Camera IOC application
</pre>
That is really not correct either.  The FLIR IOC application almost always also depends on other synApps modules (busy, calc, autosave, etc.).  Some are optional, but busy, for example, is not.
I would also like to point out that when one runs “make release” in the top-level synApps support/ directory above areaDetector it will correctly update areaDetector/configure/RELEASE_LIBS.local and RELEASE_PRODS.local to use the versions defined in synApps/support/configure/RELEASE
For example here are snippets from areaDetector/configure/RELEASE_LIBS.local and RELEASE_PRODS.local where ASYN, AREA_DETECTOR, and EPICS_BASE are set to nothing:
RELEASE_LIBS.local
#RELEASE Location of external products
# Run "gnumake clean uninstall install" in the application
# top directory each time this file is changed.
# If using Debian packages then the following must be done:
#  SUPPORT should be defined to be the root location of any modules which should NOT come from the Debian package.
#  Any modules which should come from the Debian package should be commented out, except for EPICS_BASE.
#  For example to use a newer version of asyn and areaDetector then define ASYN, AREA_DETECTOR, ADCORE,
#  and ADSUPPORT here.  To use the Debian version of asyn then comment out ASYN here.
# If you don't want to install into $(TOP) then
# define INSTALL_LOCATION_APP here
#INSTALL_LOCATION_APP=<fullpathname>
# ASYN is needed for base classes
ASYN=
AREA_DETECTOR=
# ADSupport is needed by ADCore plugins
ADSUPPORT=$(AREA_DETECTOR)/ADSupport
# ADCORE for base classes and plugins
ADCORE=$(AREA_DETECTOR)/ADCore
EPICS_BASE=
RELEASE_PRODS.local
#  and ADSUPPORT here, but comment out AUTOSAVE, BUSY, etc.
ASYN=
AREA_DETECTOR=
#AUTOSAVE is needed for save_restore
AUTOSAVE=
At the top level of synApps/support I then run “make release”.
corvette:~/devel>make release
It then updates RELEASE_LIBS.local and RELEASE_PRODS.local to the versions in use.
RELEASE_LIBS.local
ASYN=$(SUPPORT)/asyn-4-36
AREA_DETECTOR=$(SUPPORT)/areaDetector-3-7
EPICS_BASE=/corvette/usr/local/epics-devel/base-7.0.3
RELEASE_PRODS.local
AUTOSAVE=$(SUPPORT)/autosave-5-10
# BUSY is needed for busy record
BUSY=$(SUPPORT)/busy-1-7-2
# CALC is needed for the sseq record that is used for the reset in NDStats.template
# and which is loaded into the example IOCs for general purpose use.
# CALC is also needed for scalcout record that SSCAN uses
CALC=$(SUPPORT)/calc-3-7-3
Thus in many cases it is not necessary to edit these files in areaDetector/configure.
From: [email protected] <[email protected]> on behalf of Jeong Han Lee via Tech-talk <[email protected]>
Sent: Wednesday, August 21, 2019 6:00 PM
To: Johnson, Andrew N.; EPICS tech-talk
On 8/22/19 12:54 AM, Jeong Han Lee wrote:
> Hi Andrew,
> On 8/21/19 8:14 PM, Johnson, Andrew N. via Tech-talk wrote:
>> I realise there probably aren't many sites out there using the HZB
>> Sumo package <https://goetzpf.bitbucket.io/sumo/>, but has anyone who
>> does use it worked out how to configure and build AreaDetector with
>> it, either as a series of separate modules or as one big module?
>> Unlike most EPICS modules AreaDetector has multiple kinds of RELEASE
>> files that need to be populated, and a non-trivial configuration
>> process (which is well-documented
>> <https://areadetector.github.io/master/install_guide.html>).
>> The Sumo tool automates the configuration and building of sets of
>> EPICS modules on demand, but I'm not sure if it can cope with
>> configuring AreaDetector. If someone has succeeded in doing so I would
>> be grateful to hear details or ideas how best to approach it — I
>> haven't tried yet and I will need to do that soon.
>     If the Sumo tool does its job well with the most EPICS modules, I
> think, the tool does the same job on the AreaDetector also. But we may
> not use the current global configuration files of areadetector with the
> Sumo tool, because here we (ESS) can build them as individual modules,
> and combine "necessary components" to build "an Application" and run an
> IOC without any issues.
>     For example, in order to see images from a PointGrey  (FLIR) camera,
>     Here (ESS), we define system libraries and ADSupport clearly in
> terms of OS. And we compile ADSupport as a module, And we compile ADCore
> which has the maximum configuration options with both dependent
> libraries (system and ADSupport) together. And we compile ADPointGrey
> according to ADCore, ADSupport, and system libraries. (Note that the
> vendor libraries also we have to consider.)
>     The full dependent chain for my example (ignore system libraries and
> vendor lib) is
>     EPICS Base < Asyn < ADsupport < ADCore < ADPointGrey < FLIR Camera
> IOC application
<pre>
                                V
</pre>
     Best,
     Han
>     In addition, you also have to consider how you would like to handle
> all template files and configuration files in the different manners.
>     BTW, how Debian-based facilities does handle the areadetector?
>     HTH,
>     Han
>> - Andrew
>> Complexity comes for free, Simplicity you have to work for.
Re: Is anyone building AreaDetector with Sumo? Jeong Han Lee via Tech-talk
Is anyone building AreaDetector with Sumo? Johnson, Andrew N. via Tech-talk
Prev: RE: CameraLink and ADPCO Mark Rivers via Tech-talk
Next: Re: Is anyone building AreaDetector with Sumo? Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Is anyone building AreaDetector with Sumo? Jeong Han Lee via Tech-talk
ANJ, 22 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
