Hey Andrew,
just when your mail arrived, I was looking through the output of make
and found a line, where g++ was used for compiling using the correct
flags. Like you said...
I now replaced USR_CFLAGS by ARCH_DEP_CFLAGS and added
ARCH_DEP_LDFLAGS +=
--sysroot=/opt/iseg/cross-compiler/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi
Now it works! Thanks for your help!
Cheers,
Florian
On 8/29/19 9:23 PM, Johnson, Andrew N. via Tech-talk wrote:
Hi Florian,
On 8/29/19 1:33 PM, Florian Feldbauer via Tech-talk wrote:
My configure/os/CONFIG_SITE.linux-x86-64.linux-arm looks like this
GNU_TARGET = arm-angstrom-linux-gnueabi
GNU_BIN =
/opt/cross-compiler/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi
COMMANDLINE_LIBRARY = READLINE_NCURSES
USR_CFLAGS += -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
USR_CXXFLAGS += -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
Looking at the compiler commands executed by make below, only the
USR_CFLAGS are used when compiling c files, but the CXXFLAGS are
ignored.
USR_CFLAGS is used when compiling .c files to .o
USR_CXXFLAGS is used when compling .cpp/.cxx/.cc flags to .o
USR_LDFLAGS is used when linking .o files together into executables or
libraries.
It's the latter (link) stage that is failing in your build. Your first
command is a compilation of a C file, which succeeds:
/opt/iseg/cross-compiler/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gcc
-D_GNU_SOURCE -D_DEFAULT_SOURCE -march=armv7-a -mthumb
-DUNIX -Dlinux -O3 -g -Wall -march=armv7-a -mthumb
-fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc
-I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux
-I../../src/osi/os/posix -I../../src/osi/os/default -I..
-I../../src/as -I../../src/bucketLib -I../../src/calc
-I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates
-I../../src/dbmf -I../../src/ellLib -I../../src/env
-I../../src/error -I../../src/fdmgr -I../../src/flex
-I../../src/freeList -I../../src/gpHash -I../../src/iocsh
-I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi
-I../../src/pool -I../../src/ring -I../../src/taskwd
-I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl
-I/opt/epics/base/include/compiler/gcc
-I/opt/epics/base/include/os/Linux -I/opt/epics/base/include
-c ../../src/yajl/yajl_parser.c
The next command is actually using g++ to link object files into a
library (libCom.so.3.17.5), it isn't actually compiling anything, so
it doesn't get given your $(USR_CXXFLAGS):
/opt/iseg/cross-compiler/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-g++
-o libCom.so.3.17.5 -shared -fPIC -L/opt/epics/base/lib/linux-arm
-Wl,-rpath,/opt/epics/base/lib/linux-arm -rdynamic asLib.o
asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o
resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o
envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o
fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o
libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o
alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o
epicsExit.o epicsStdlib.o epicsString.o truncateFile.o
ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o
epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o
epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o
osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o
epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o
osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o
epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o
osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o
osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o
devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o
osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o
epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o
timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o
yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o
yajl_parser.o -lpthread -lreadline -lncurses -lm -lrt -ldl
-lgcc
The last command breaks because the --sysroot option is missing and
the compiler doesn't find it's libraries.
Did I do something wrong? What is the correct way to define default C
compiler and C++ compiler flags when cross-compiling?
You didn't set a variable to provide the linker flags needed for your
build. Following your other settings that would be USR_LDFLAGS, but I
would recommend that you actually set these variables instead:
ARCH_DEP_CFLAGS = <your USR_CFLAGS value above>
The ARCH_DEP_CXXFLAGS variable defaults to $(ARCH_DEP_CFLAGS) so you
don't need to set this at all.
ARCH_DEP_LDFLAGS = <flags to pass to g++ when using it as a linker>
I'm suggesting you use the ARCH_DEP_ flags instead of the USR_ ones
because some application Makefiles may override the USR_ variables
instead of just appending to them, which would cause your builds to fail.
Hope this helps,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
- Re: Cross compiling Florian Feldbauer via Tech-talk
- Cross compiling Florian Feldbauer via Tech-talk
- Re: Cross compiling Johnson, Andrew N. via Tech-talk
areaDetector NDPluginTimeSeries errors Miceli, Antonino via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
