1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer]
To: "Engbretson, Mark S." <[email protected]>, Ashish Sharma <[email protected]>
Date: Wed, 4 Sep 2019 11:55:52 +0000
Hi Ashish,
> Message: Identical process variable names on multiple servers
These errors a coming because you have more than one network card on your machine, and you are running both the EPICS IOC and the EPICS client (medm) on the same machine.  This is an annoying problem with EPICS, but it is easy to fix.
You need to set these environment variables
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_ADDR_LIST=xxx.xxx.xxx.xxx
where xxx.xxx.xxx.xxx is the broadcast address of the network you want to use for EPICS Channel Access.  It is typically the public network interface of your machine, rather than one of the private network interfaces.  On my machine I might have private network address of 192.168.0.1 and a public network address of 164.54.160.202.  I set EPICS_CA_ADDR_LIST=164.54.160.255 because the netmask of the public interface is 255.255.255.0.
> I have both ADGenICam and ADSpinnaker built in my system but I tried first wiith AravisGigE after reading T. Cobb's
> comment that it should work with GigEVision camera. Am I mistaken here?
> I found setting up ADSpinnaker setup a bit difficult in comparison to aravisGigE. Can you please help here?
You actually have 4 choices of drivers to use with that camera.
- aravisGigE.  This is based on the aravis package.  It runs on most any version of Linux, and it should work fine.
- ADAravis.  This is also based on aravis, but uses the new ADGenICam base class.  It also runs on most any version of Linux, and it should work.  It queries camera properties more frequently than aravisGigE and so has performance problems with some cameras because aravis does not currently properly cache camera registers.  The aravis developer is working on this problem.
- ADSpinnaker.  This uses the new Spinnaker SDK from FLIR.  It runs on Windows and Linux.  The SDK is built with very recent version of gcc so they only claim it works on Ubuntu 18.  In fact it may work on Ubuntu 16, and it has been tested on RHEL8.
- ADPointGrey.  This uses the older FlyCap2 SDK from FLIR/Point Grey.  It runs on Linux and Windows.  The version of the FlyCap2 SDK included in ADPointGrey runs on RHEL7, although the more recent versions of the SDK require Ubuntu (16 or 18?).
> Still I am unable to see the ImageJ display and NX, NY, NZ still being blank with 0.0 Frames/s. [ Duplicate issue of PV in ImageJ is still there even after EPICS_CA_ADDR_LIST setup].
Are there any errors in the ImageJ log window?
> Also the medm screens does not show any histogram etc. plots however, it seem to acquire from camera. [I have enable SCIPLOT in medm installation and commented out Xrtgraph]
Have you enabled callbacks on the plugins in question?  NDPluginStdArrays or NDPluginPva for ImageJ, depending on which ImageJ plugin you are using.  NDPluginStats for the histogram plugin.  If you still have problems please send a screen shot of those plugin screens.
From: [email protected] <[email protected]> on behalf of Ashish Sharma via Tech-talk <[email protected]>
Sent: Wednesday, September 4, 2019 6:04 AM
To: Engbretson, Mark S.
Cc: tech-talk
Hi Mark,
Thanks for your response.
EPICS_DISPLAY_PATH setup could recognize the missing .adl files and that error has gone but the follwing long list is still appearing as soon as I am opening my camera link in medm,
Wed Sep 04 14:44:02 IST 2019
medmCAExceptionHandlerCb: Channel Access Exception:
  Channel Name: Unavailable
  Native Type: Unavailable
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:Gain", Connecting to: 169.254.0.2:5064, Ignored: 10.1.15.37:5064
  Requested Type: TYPENOTCONN
  Requested Count: 0
  Source File: ../cac.cpp
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:DataType_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
I have both ADGenICam and ADSpinnaker built in my system but I tried first wiith AravisGigE after reading T. Cobb's comment that it should work with GigEVision camera. Am I mistaken here?
Please help.
Thanks.
Ashish
To: "Ashish Sharma" <[email protected]>
Cc: "tech-talk" <[email protected]>
Sent: Wednesday, September 4, 2019 3:32:41 PM
First of all, you do not have the EPICS_DISPLAY_PATH variable set that points to the location of the adl files in ADCore.
If you are using a FLIR camera, you should probably be using just the GenICam and ADSpinnaker directories, not the Aravis ones.
The duplicate PV's are caused my most OS's these days having more than 1 ethercard, or virtual ethernet cards. You normally solve this by setting the EPICS_CA_ADDR_LIST to a single ip # ( or even to 127.0.0.1) and setting EPICS_AUTO_ADDR_LIST to NO
On Sep 4, 2019, at 04:26, Ashish Sharma via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Dear all,
I am trying to configure and use FLIR BFS-PGE-16S2C-CS camera for beam viewing application. This camera has GigEVision interface.
My system has Ubuntu 16.04, 32-bit version.
Successfully tested Acquisition app of Spinnaker SDK to capture 10 images.
I have installed AreaDetector module successfully and also configured the aravisGigE module of areaDetector. arv-tool-0.6 successfully recognized my camera and using the following link I was able to generate the .template file, .edl, -feature.edl, and .adl files successfully.
http://controls.diamond.ac.uk/downloads/support/aravisGigE/0-1-9/documentation/doxygen/index.html
I then added the following to my st.cmd file in aravisGigE/iocs/aravisGigEIOC/iocBoot/iocAravisGigE
aravisCameraConfig("$(PORT)", "FLIR-19308820")
dbLoadRecords("$(ARAVISGIGE)/db/FLIR-19308820.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
This is corresponding to my Camera ID.
then upon running ./start_epics it loads the db from template (~ 1202 PVs).
Next I installed the MEDM package successfully and ran
medm -x aravisTop.adl
It starts the top menu and when I select my camera from drop-down, (infact any of the listed cameras), it gives following console output simultaneously opening the control page for camera with features listed as well:
MEDM Version 3.1.14: Loading aliased fonts.................
compositeFileParse: Cannot open file
  filename: ADSetup.adl
  filename: ADPlugins.adl
  filename: ADShutter.adl
  filename: ADAttrFile.adl
  filename: ADBuffers.adl
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ArraySizeX_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ArraySizeY_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ColorMode", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ColorMode_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:AcquireTime", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:AcquireTime_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:AcquirePeriod", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:AcquirePeriod_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:NumImages", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:NumImages_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:NumImagesCounter_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ImageMode", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ImageMode_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:TriggerMode", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:TriggerMode_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:TriggerSoftware", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:Acquire", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:BinX", Connecting to: 169.254.0.2:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:TimeRemaining_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:DetectorState_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ArrayCounter", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
  Native Count: 0
  Access: Unavailable
  Host: Unavailable
  Context: Channel: "13ARV1:cam1:ArrayCounter_RBV", Connecting to: llrf-Control.local:5064, Ignored: 10.1.15.37:5064
  Requested Count: 0
  Line number: 1308
Too many exceptions [25]
No more will be handled
Please fix the problem and restart MEDM
Upon Pressing "Acquire" button, the camera link LED is constant ON and I think it starts acquiring as well.
After that I installed ImageJ and Java on my PC and subsequently added and complied/run the EPICS_areaDetector Plugins (i.e. EPICS AD Controller, EPICS AD Viewer, EPICS NTNDA Viewer).
When I started EPICS AD Viewer and added my PV prefix as 13ARV1:image1: (it is shown in green highlight) and status is 4/9/2019 14:49:51.869: Connected to EPICS PVs OK
But on pressing Start nothing happens, 4/9/2019 14:51:23.206: Image display started message is displayed but no display is actually started and NX, NY, NZ and Frames/s boxes are still empty.
However, the console of ImageJ shows the following issues:
Sep 04, 2019 2:02:30 PM com.cosylab.epics.caj.CAJContext searchResponse
INFO: More than one PVs with name '13ARV1:Over1:1:PositionX' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:Over1:1:PositionY' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:Over1:1:SizeX' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:Over1:1:SizeY' detected, additional response from: /169.254.0.2:5064
Sep 04, 2019 2:02:32 PM com.cosylab.epics.caj.CAJContext searchResponse
INFO: More than one PVs with name '13ARV1:ROI1:MinX' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:MinY' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:MinX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:MinY_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:BinX' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:BinY' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:ReverseX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:ReverseY_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:SizeX' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:SizeY' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:ArraySizeX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:ROI1:ArraySizeY_RBV' detected, additional response from: /169.254.0.2:5064
Sep 04, 2019 2:02:34 PM com.cosylab.epics.caj.CAJContext searchResponse
INFO: More than one PVs with name '13ARV1:Trans1:Type' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:Trans1:ArraySizeX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:Trans1:ArraySizeY_RBV' detected, additional response from: /169.254.0.2:5064
Sep 04, 2019 2:02:36 PM com.cosylab.epics.caj.CAJContext searchResponse
INFO: More than one PVs with name '13ARV1:cam1:MinX' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:MinY' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:MinX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:MinY_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:SizeX' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:SizeY' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:ArraySizeX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:ArraySizeY_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:MaxSizeX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:MaxSizeY_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:BinX_RBV' detected, additional response from: /169.254.0.2:5064
Sep 04, 2019 2:02:37 PM com.cosylab.epics.caj.CAJContext searchResponse
INFO: More than one PVs with name '13ARV1:cam1:BinY_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:ReverseX_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:cam1:ReverseY_RBV' detected, additional response from: /169.254.0.2:5064
Sep 04, 2019 2:04:19 PM com.cosylab.epics.caj.CAJContext searchResponse
INFO: More than one PVs with name '13ARV1:image1:ArraySize0_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:image1:ArraySize1_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:image1:ArraySize2_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:image1:ColorMode_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:image1:DataType_RBV' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:image1:ArrayData' detected, additional response from: /169.254.0.2:5064
INFO: More than one PVs with name '13ARV1:image1:ArrayCounter_RBV' detected, additional response from: /169.254.0.2:5064
Sep 04, 2019 2:14:59 PM com.cosylab.epics.caj.CAJContext searchResponse
Sep 04, 2019 2:19:08 PM com.cosylab.epics.caj.CAJContext searchResponse
Sep 04, 2019 2:23:53 PM com.cosylab.epics.caj.CAJContext searchResponse
Sep 04, 2019 2:23:54 PM com.cosylab.epics.caj.CAJContext searchResponse
Sep 04, 2019 2:48:13 PM com.cosylab.epics.caj.CAJContext searchResponse
Sep 04, 2019 2:48:14 PM com.cosylab.epics.caj.CAJContext searchResponse
Sep 04, 2019 2:49:51 PM com.cosylab.epics.caj.CAJContext searchResponse
Since, I am an EPICS user (not developer) and a beginner, I am unable to comprehend this situation to view the Image Display. Please help of in resolving this issue.
Please let me know if anything else needs to be done from my side.
Thanks and regards
Ashish Sharma
Engineer 'C'
Inter-University Accelerator Centre,
Aruna Asaf Ali Marg, New Delhi - 110067, India
Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Ashish Sharma via Tech-talk
Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Engbretson, Mark S. via Tech-talk
Prev: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Ashish Sharma via Tech-talk
Next: Re: pvGet in Sequence does not work with incorrect size Simon Reiter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Ashish Sharma via Tech-talk
ANJ, 05 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
