Hi:
I don't see anything in particular wrong with your code to add a mouse click listener, but I think it doesn't work because the widget itself, specifically the IntensityGraphFigure, already has a mouse listener attached which ends in "event.consume()", so your listener no longer gets the events. The widget does this because it's using the mouse events to support zooming and moving the ROIs.
One "fix" would be an update to the widget's IPixelInfoProvider to have it not only receive the coordinates but also the mouse button states.
But that would still leave you scripts to handle the cursor position. In comparison, the corresponding Image widget in the Display Builder directly supports sending the cursor position, either on click or with each move, to X/Y PVs or to a PVAccess table, so you could try to add similar features to the BOY Intensity Graph.
Kay
- MouseListener and MouseEvent on Intensity Graph in CSS Apeksha Chipade - UKRI STFC via Tech-talk
CSS jython setvalue behaviour Pilar via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
