1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvGet in Sequence does not work with incorrect size
From: Benjamin Franksen via Tech-talk <[email protected]>
To: <[email protected]>
Date: Tue, 17 Sep 2019 16:18:30 +0200
Am 17.09.19 um 11:38 schrieb Dejan Kocjan via Tech-talk:
> We found out that the difference between monitor/ca_create_subscription()
> and pvGet/ca_array_get_callback(), is that pvGet will fail, if number of
> requested elements is more than NELM of the record. While monitor will not
> fail.
Okay, I didn't know that.
> This could be solved by making sure number of requested elements does not
> exceed NELM, like it is already done for pvPut. Instead of reading
> ch->count, we should read dbch->dbCount.
That makes sense, will fix. Thanks for debugging this!
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: pvGet in Sequence does not work with incorrect size Dejan Kocjan via Tech-talk
Prev: Re: pvGet in Sequence does not work with incorrect size Dejan Kocjan via Tech-talk
Next: Sequencer release 2.2.7 Benjamin Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: monitoring field device Pierrick M Hanlet via Tech-talk
ANJ, 17 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
