1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ENVVAR.right_trim in IOC console
From: Till Straumann via Tech-talk <[email protected]>
To: "Jemian, Pete R." <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Sun, 29 Sep 2019 20:35:54 -0700
It would probably be easy to wrap std:: or boost:: regex_replace() into
a iocsh call with, e.g., 'sed'-like syntax so that you could say
epicsEnvSetSubstituted( "IOCNAME", "/(^.*)(.$)/\1/", "$(PREFIX)" )
that would give you a quite powerful tool...
HTH
- Till
On 9/29/19 6:35 PM, Jemian, Pete R. via Tech-talk wrote:
Working in the IOC shell (EPICS base 7.0.3), how to remove the last
character from an EPICS environment variable?
given this definition:   epicsEnvSet(PREFIX, "xxx:")
I want to achieve this result: "xxx" by somehow editing $(PREFIX) in place.
In bash, this is possible using ${PREFIX::-1} but in the IOC shell:
iocxxx> echo $(PREFIX::-1)
macLib: macro PREFIX::-1 is undefined (expanding string echo $(PREFIX::-1))
The context is I want to change this line from:
dbLoadRecords("some.db","IOCNAME=$(PREFIX)")
to:
dbLoadRecords("some.db","IOCNAME=$(PREFIX - 1 character)")
Re: ENVVAR.right_trim in IOC console Jemian, Pete R. via Tech-talk
Prev: Re: ENVVAR.right_trim in IOC console Eric Norum via Tech-talk
Next: Re: ENVVAR.right_trim in IOC console Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
