1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: iocLogServer, logstash & procServ
From: Alfio Rizzo via Tech-talk <[email protected]>
Date: Tue, 8 Oct 2019 10:21:51 +0000
I read that maybe iocLogServer will be dismissed and that logstash has some drop connection issue.
I am using instead procServ to listen on caPutLog port running a simple infinite-loop script.
In this way caPutLog write its output to procServ logfile.
I think that procServ is good replacement for both iocLogServer and logstah, unless there are some advantages that the others have.
@Ralph, is there any option to make procServ to listen forever without the need to run any command (e.g. my infinite loop script)?
Best
Alfio
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
RE: iocLogServer, logstash & procServ Kivel Niko (PSI) via Tech-talk
Prev: RE: [EXTERNAL] updating ADAndor from RHEL6 to RHEL7 Pearson, Matthew R. via Tech-talk
Next: RE: iocLogServer, logstash & procServ Kivel Niko (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Ludlum Model 4600 Multi-Detector Counter Ernesto Paiser via Tech-talk
ANJ, 08 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
