1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn port driver generate parameters
To: 'Tynan Ford' <[email protected]>
Date: Mon, 14 Oct 2019 18:40:35 +0000
Hi Tynan,
I am using that approach in the ADGenICam base class in areaDetector.  ADGenICam is the base class for the ADAravis, ADSpinnaker, and ADVimba derived classes.
The documentation describing how it works is here:
https://areadetector.github.io/master/ADGenICam/ADGenICam.html#adgenicam-class
The code is in the ADGenICam::drvUserCreate() method in ADGenICam.cpp:
https://github.com/areaDetector/ADGenICam/blob/master/GenICamApp/src/ADGenICam.cpp#L269
Let me know if you have any questions.
From: Tech-talk <[email protected]> On Behalf Of Tynan Ford via Tech-talk
Sent: Monday, October 14, 2019 1:16 PM
To: [email protected]
Subject: Asyn port driver generate parameters
At ICALEPCS it sounded like some people are auto generating their asyn port driver parameters outside of the C++ file. Is this correct? If so are there any projects using this approach or documentation that I could be pointed to?
Tynan
Asyn port driver generate parameters Tynan Ford via Tech-talk
Prev: Asyn port driver generate parameters Tynan Ford via Tech-talk
Next: Re: fast PV transition skipped in EPICS 3.16 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Streamdevice segmentation fault Brown, Garth via Tech-talk
ANJ, 15 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
