1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: clarification on PV name max length
From: Alfio Rizzo via Tech-talk <[email protected]>
Date: Wed, 23 Oct 2019 13:56:10 +0000
Hi
Sorry if I am resuming an old thread,
But I did not find any updated documentation about this topic.
According to the EPICS wiki (which I think is not updated)
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon
The max allowed characters for PV name are 60 + NULL
Which is common all the records type.
However if I look at the ai record wiki in the Display Parameter section
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Input#Operator_Display_Parameters
I see that there is a limitation on the displayed .NAME field which is 29 char + NULL
even if it I guess from 3.15 on is 39 + NULL.
Could you please clarify why you have this limitation when the .NAME field is called ?
Thanks
Alfio
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
Re: clarification on PV name max length Johnson, Andrew N. via Tech-talk
Prev: PVAccess for Go Quentin Smith via Tech-talk
Next: Re: clarification on PV name max length Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 23 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
