1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: missing addRecord.h
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Wed, 30 Oct 2019 19:16:54 +0000
Hi Pierrick,
addRecord.h is part of Marty Kraimer's pvDatabase module, which is part of EPICS 7.0.3. If you've built Base-7.0.3 properly with the V4 submodules it should have been installed into the include/pv directory when that submodule was built.
If you built Base-7.0.3 from a git clone instead of from the tar-file, did you use 'git clone --recursive' to check it out? Running 'git submodule status' should list 6 submodules. If it doesn't, running 'git submodule update --init' should pull in the necessary submodules, after which a 'make' at the top level will build them.
HTH,
- Andrew
On 10/30/19 2:05 PM, Pierrick M Hanlet via Tech-talk wrote:
I'm attempting to learn to use structured data in EPICS7 and so looking
at the
tutorials.  I find it a bit difficult to navigate because many of the
tutorials point
back to v4, which I understand, but then I don't know if there's something
newer (hence the difficulty in navigation).
I found a recent post on tech-talk, msg01128, and am attempting to build
exampleCPP from "https://github.com/epics-base".  However, when trying to
build exampleDatabase.cpp, it fails on missing addRecord.h, which doesn't
exist in this example code nor in base-7.0.3.
Pierrick
Complexity comes for free, Simplicity you have to work for.
Re: missing addRecord.h Johnson, Andrew N. via Tech-talk
missing addRecord.h Pierrick M Hanlet via Tech-talk
Prev: missing addRecord.h Pierrick M Hanlet via Tech-talk
Next: Re: building synApps from Git Lang, Keenan C. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: missing addRecord.h Johnson, Andrew N. via Tech-talk
ANJ, 30 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
