1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Monitored PV limit?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 8 Nov 2019 17:22:47 +0100
Hi Aaron,
Assuming you refer to the caMonitor example code that comes with Base: this is an example for how to use the CA client library. In its sources it sets (line 27)
#define MAX_PV 1000
which is most probably the limit you are experiencing.
For monitoring 5000 values, a command line client does not sound like a reasonable tool. If you can give some more details on your use case, there might be better ways to get it done.
Cheers,
~Ralph
On Fri, 8 Nov 2019 at 17:09, Aaron Brown via Tech-talk <[email protected]> wrote:
Hello All,
I have a list of roughly 5000 PVs that I would like to monitor, but when I run the "./caMonitor" program with the full list it seems to only monitor less than half of the list.
Is there a limit to the number of PVs that can be monitored using the example "./caMonitor" program?
Thanks for any help that can be offered,
Aaron Brown
Detector Support Group
Jefferson Lab
Re: [EXTERNAL] Re: Monitored PV limit? Aaron Brown via Tech-talk
Prev: Monitored PV limit? Aaron Brown via Tech-talk
Next: RE: ADAndor iKon CCD low saturation point Heesterman, Peter J via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [EXTERNAL] Re: Monitored PV limit? Aaron Brown via Tech-talk
ANJ, 08 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
