Hi Kiman,
You need memDisplay[1] in order to compile regdev[3] correctly.
And there may be one more dependent module, symbolname [2]. Please
look at
https://github.com/paulscherrerinstitute/memDisplay/blob/master/configure/RELEASE#L22
However, symbolname doesn't have the standard EPICS building system.
HTH
Han
[1] https://github.com/paulscherrerinstitute/memDisplay
[2] https://github.com/paulscherrerinstitute/symbolname
[3] https://github.com/paulscherrerinstitute/regdev
On 11/8/19 7:52 PM, Ha, Kiman via Tech-talk wrote:
Hi Dirk,
I am trying to build a mmap & regdrv device support module for ARM64
Debian10 and got some errors.
It seems environment issue and needs additional modules?
fpga@debian10-zcu102:~/iocApp/mmap$ make
GNUmakefile:2: It seems you do not have the PSI build environment.
Remove GNUmakefile.
make -C O.linux-arm -f ../Makefile TOP=./.. \
T_A=linux-arm install
make[1]: se entra en el directorio '/home/fpga/iocApp/mmap/O.linux-arm'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUNIX
-Dlinux -g -Wall -fPIC -I. -I../O.Common -I. -I. -I..
-I./../include/compiler/gcc -I./../include/os/Linux -I./../include
-I/home/fpga/epics/base-3.16.2/include/compiler/gcc
-I/home/fpga/epics/base-3.16.2/include/os/Linux
-I/home/fpga/epics/base-3.16.2/include -c ../mmapDrv.c
../mmapDrv.c:9:10: fatal error: regDev.h: No existe el fichero o el
directorio
#include <regDev.h>
compilation terminated.
make[1]: *** [/home/fpga/epics/base-3.16.2/configure/RULES_BUILD:235:
mmapDrv.o] Error 1
make[1]: se sale del directorio '/home/fpga/iocApp/mmap/O.linux-arm'
make: *** [/home/fpga/epics/base-3.16.2/configure/RULES_ARCHS:58:
install.linux-arm] Error 2
fpga@debian10-zcu102:~/iocApp/regdev$ make
If you are not using the PSI build environment, GNUmakefile can be removed.
make[1]: se entra en el directorio '/home/fpga/iocApp/regdev/O.linux-arm'
-I/home/fpga/epics/base-3.16.2/include -MM -MF simRegDev.d
../simRegDev.c
../simRegDev.c:18:10: fatal error: memDisplay.h: No existe el fichero o
el directorio
#include "memDisplay.h"
-I/home/fpga/epics/base-3.16.2/include -MM -MF regDev.d
../regDev.c
../regDev.c:21:10: fatal error: memDisplay.h: No existe el fichero o el
directorio
-I/home/fpga/epics/base-3.16.2/include -c ../regDev.c
In file included from /home/fpga/epics/base-3.16.2/include/dbAccess.h:19,
from ../regDev.c:10:
/home/fpga/epics/base-3.16.2/include/dbBase.h:162:5: warning: ‘rset’ is
deprecated [-Wdeprecated-declarations]
rset *prset;
In file included from /home/fpga/epics/base-3.16.2/include/dbBase.h:21,
/home/fpga/epics/base-3.16.2/include/recSup.h:67:8: note: declared here
struct rset { /* record support entry table */
In file included from /home/fpga/epics/base-3.16.2/include/dbAccess.h:23,
/home/fpga/epics/base-3.16.2/include/dbAccessDefs.h:208:46: warning:
‘rset’ is deprecated [-Wdeprecated-declarations]
epicsShareFunc rset * dbGetRset(const struct dbAddr *paddr);
directorio
regDev.o] Error 1
make[1]: se sale del directorio '/home/fpga/iocApp/regdev/O.linux-arm'
- RE: Xilinx ARM64 mmap and regdev module compile error Ha, Kiman via Tech-talk
- Xilinx ARM64 mmap and regdev module compile error Ha, Kiman via Tech-talk
Re: Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
