1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: I can't figure out how to change the rate guarantee...
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Aaron Brown <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 8 Nov 2019 20:29:02 -0800
On 11/7/19 10:00 AM, Aaron Brown via Tech-talk wrote:
> Hello,
> I am using a Channel Access client to monitor a list of PVs.
> A few of them are temperature values that don't change frequently.
> However, I would like to receive a value from these PVs even if the value hasn't changed to ensure the sensor is still operational.
> Is there a way to do this?
> I read something about a "rate guarantee", but have seen no information about how to change it.
> Any help will be greatly appreciated.
It may be worth saying that this sort of verification is usually the
responsibility of an IOC.  A well designed EPICS driver will indicate
communications faults, or other read errors, with an INVALID alarm.
CA or PVA clients can (and should) look at the alarm severity
as well as the value of each monitor update.
There are of course specific cases where this really isn't enough.
eg. to drive a soft PID loop at a fixed update rate.
I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
Prev: RE: Xilinx ARM64 mmap and regdev module compile error Ha, Kiman via Tech-talk
Next: Re: [EXTERNAL] Re: Monitored PV limit? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Re: I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
Next: ADAndor iKon CCD low saturation point Pearson, Matthew R. via Tech-talk
ANJ, 08 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
