1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Accessing IOC on different subnet
From: "Bhavna N. Merh via Tech-talk" <[email protected]>
Cc: [email protected]
Date: Wed, 27 Nov 2019 15:29:43 +0530
Hello,
The responses are :
For windows PC-
APPDATA=C:\Users\Admin\AppData\Roaming
CATOOLS=C:\Program Files (x86)\National Instruments\LabVIEW 2016\user.lib\caLab\lib
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=BL09-BACKUP-PC
ComSpec=C:\WINDOWS\system32\cmd.exe
DriverData=C:\Windows\System32\Drivers\DriverData
EPICS_CA_ADDR_LIST=192.168.1.25
EPICS_CA_AUTO_ADDR_LIST=NO
For CentOS PC-
 EPICS_CA_ADDR_LIST: localhost
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_AUTO_ADDR_LIST: NO
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CA_MAX_ARRAY_BYTES: 6000000
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CAS_INTF_ADDR_LIST: localhost
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_TIMEZONE: CST/CDT::360:030802:110102
EPICS_TS_NTP_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_CMD_PROTO_PORT is undefined
EPICS_AR_PORT: 7002
IOCSH_PS1: epics>
IOCSH_HISTSIZE: 50
-Bhavna
On 27-11-2019 10:27, Mark Rivers wrote:
Hi Bhavna,
It seems to me that the setup you describe should work without setting
the EPICS environment variables at all. The IOC on B should make its
PVs available on both subnets.
At the IOC prompt on B type epicsPrtEnvParams and send the output. On
C type “set” and send the results for any environment variables
starting with EPICS.
Are the subnet masks all set correctly? It looks like they should be
255.255.255.0.
Sent from my iPhone
On Nov 26, 2019, at 9:22 PM, Bhavna N. Merh via Tech-talk <[email protected]> wrote:
I have a device (say A) and 2 PCs (B and C)
B a CentOS 7 PC  has 2 NICs. C is a windows 10 PC.
A and B are on one subnet (IP addr of both respectively: 192.168.0.2 and 192.168.0.1)
B and C are on another subnet (IP addr: 192.168.1.23 and 192.168.1.25)
The IOC runs on B and gathers data from device A.
I am unable to access the PVs from C. caget says channel connection timeout. (All firewalls are disabled)
Suggest what to write in EPICS_CA_ADDR_LIST and where.
Bhavna N. Merh
Scientific Officer, Accelerator Control Systems Division
Raja Ramanna Centre for Advanced Technology
Indore, Madhya Pradesh, India -452013
Ph:(0731)248-8055
"Complexity comes for free, Simplicity you have to work for."
Re: Accessing IOC on different subnet Mark Rivers via Tech-talk
Re: Accessing IOC on different subnet Johnson, Andrew N. via Tech-talk
Accessing IOC on different subnet Bhavna N. Merh via Tech-talk
Prev: Re: MEDM install result Torsten Bögershausen via Tech-talk
Next: Getting TOD Stefen Paul via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Accessing IOC on different subnet Mark Rivers via Tech-talk
Next: Re: Accessing IOC on different subnet Mark Rivers via Tech-talk
ANJ, 27 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
