1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ADSpinnaker timestamp
To: Tamas Kerenyi <[email protected]>
Date: Tue, 10 Dec 2019 22:09:56 +0000
Hi Tamas,
These are the values of the ChunkTimeStamp you measured.  They are coming every 2 seconds, plus or minus a few ms.
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:34.642297 1557832136
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:36.640736 -737150176
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:38.641100 1262848184
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:40.643660 -1032134232
I just realized we can make sense of those as timestamps in ns, but we are missing the high-order bits which increment about every 4 seconds.
Here I convert the 4 times above to unsigned 32-bit numbers.
IDL> t1 = 1557832136
IDL> t2 = ulong(-737150176)
IDL> t3 = 1262848184
IDL> t4 = ulong(-1032134232)
IDL> print, t1, t2, t3, t4
  1557832136  3557817120  1262848184  3262833064
Note that times 1 and 2 are separated by about 2000000000 counts, as are times 3 and 4.  Clearly the 32-bit integer overflowed between times 2 and 3.  So we add 2^32 to times 3 and 4 to compensate for this overflow and convert them to 64-bit integers.
IDL> t3 = t3 + 2LL^32
IDL> t4 = t4 + 2LL^32
  1557832136  3557817120            5557815480            7557800360
Now we look at the difference between the timestamps.
IDL> print, t2-t1, t3-t2, t4-t3
  1999984984            1999998360            1999984880
Note that they are all very close to 2000000000 = 2e9.  Since your images were 2 seconds apart, this means these timestamps are indeed ns, and the jitter looks likes it is about 500 ns.
Sent: Tuesday, December 10, 2019 1:30 PM
To: Tamas Kerenyi
Cc: [email protected]
I think I understand why the ChunkTimestamp is jumping between positive and negative. GenICam integers are 64 bits. ADGenICam truncates them to 32 bits.
EPICS base, asyn, and ADCore have all recently added support for 64 bit integers. I could thus change ADGenICam to use int64in and int64out records for GenICam integers. This would however require EPICS base 3.16.1 or later.
Sent from my iPhone
On Dec 10, 2019, at 10:32 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Tamas,
What camera are you using?
In ADSpinnaker there is a PV to tell the driver to use the embedded time stamp from the camera for the timeStamp property of the NDArray.  If you select this you may not need the ChunkTimestamp.
The timeStamp is saved in the TIFF, HDF5, and netCDF file writing plugins.
Sent from my iPhone
On Dec 10, 2019, at 8:28 AM, Tamas Kerenyi via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi!
I'm using ADSpinnaker. How should I interpret the "ChunkTimestamp"? I'd like to know the timestamp of the pictures in nanoseconds.
Best Regards,
Tamas Kerenyi
ICS Division, HW and Integration Group
RE: ADSpinnaker timestamp Tamas Kerenyi via Tech-talk
Re: ADSpinnaker timestamp Mark Rivers via Tech-talk
Prev: Re: ADSpinnaker timestamp Mark Rivers via Tech-talk
Next: Old base version bug in configure/os/CONFIG_SITE.linux-x86_64.UnixCommon Di Wang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: RE: ADSpinnaker timestamp Tamas Kerenyi via Tech-talk
ANJ, 13 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
