1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Certificate issue for epics.anl.gov
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: "Konrad, Martin" <[email protected]>, Andrew Johnson <[email protected]>
Date: Thu, 12 Dec 2019 15:25:16 +0100
Martin, could you please try again ?
At least for me, it works now.
Thanks guys for fixing it.
On 12/12/19 14:27, Konrad, Martin via Tech-talk wrote:
Hi Andrew,
I'm running into TLS issues when accessing epics.anl.gov. Firefox
reports SSL_ERROR_BAD_CERT_DOMAIN. Looking at the certificate there is
indeed a problem: The Common Name field contains "*.aps.anl.gov" which
doesn't match "epics.anl.gov".
It seems like the certificate has been replaced recently.
-Martin
Certificate issue for epics.anl.gov Konrad, Martin via Tech-talk
Prev: Building Epics base 3.15.7 on Windows 7 64bit Sintschuk, Michael via Tech-talk
Next: RE: Certificate issue for epics.anl.gov Konrad, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Certificate issue for epics.anl.gov Konrad, Martin via Tech-talk
ANJ, 12 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
