1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: processing pva records
From: Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Wed, 18 Dec 2019 21:51:49 +0000
Hi all,
I am developing a module for use at Fermilab which allows an easy interface
from EPICS IOCs to our native control system.  I want to use aSub records
so that I have the flat db files which can be populated with macros.
Within
my module I've created a structure, v7Struct which carries all of the
pertinent
information; e.g. Reading and Setting.  At initialization, I instantiate
as many
of these objects (v7Structs) as I need.
So, to read from my v3 PVs, I do:
v3PV -> aSub(Reading) -> v7Struct -> operator (via native system)
This works well.  Where I'm having difficulty is the other way around:
operator -> v7Struct ->(?) aSub(Setting) -> v3PV
In other words, I don't know how to get my v7Struct to process my
aSub(Setting).
I've been going through exampleCPP, which is a very helpful work, but thin
on documentation.  Do I need to set up a PvaClient and set up monitor and
then a link, or is there someway to do this directly from PVData or
PVDatabase?
Thank you,
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: processing pva records Michael Davidsaver via Tech-talk
Prev: processing pva records pmhanlet via Tech-talk
Next: ci-scripts 2.0.1 maintenance release Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: processing pva records Michael Davidsaver via Tech-talk
ANJ, 19 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
