Subject: Re: Ethernet question
From: "J. Lewis Muir via Tech-talk" <[email protected]>
Date: Mon, 6 Jan 2020 14:39:21 -0600
On 12/23, Mark Rivers via Tech-talk wrote:
> On further investigation I found that the problem only occurs when using 10 Gbit Ethernet adapters.  When using a 1 Gbit adapter it works fine.  I was able to see this in a single machine that has both 10 Gbit and 1 Gbit adapters.  If I use the 1 Gbit adapter it works fine, if I use the 10 Gbit adapter it fails (but kind of works as described above).  On 3 separate systems 1 Gbit works, and 3 other systems 10 Gbit fails.
Is the NIC driver the same for the 1 GbE and the 10 GbE NICs on Linux?
Do you have a Windows machine with a 10 GbE NIC that you could try?
Do you have a Mac with a 10 GbE NIC that you could try?
Lewis
RE: Ethernet question Mark Rivers via Tech-talk
Prev: Re: New sequencer release 2.2.8 J. Lewis Muir via Tech-talk
Next: Re: Ethernet question J. Lewis Muir via Tech-talk
Prev: Re: Ethernet question Hinko Kocevar via Tech-talk
Next: RE: Ethernet question Mark Rivers via Tech-talk
