Subject: "st.cmd" internal code question
To: <[email protected]>
Date: Wed, 08 Jan 2020 18:15:12 +0900
hi
I'm a developer new to EPICS.
   My goal is to analyze / modify the project completed by the staff. (He is not here)
  I have a product that installs an IOC on the Raspberry pi 3+ and controls the motor via the RS232 line.
  Installed on Pi 3+ are asyn4-34, motor-R6-10-1, stream, ipac-2.15 and calc-R3-6-1.
Question 1. ) MTestSetup (1,7,10) and MTestConfig (0, "SERIALPORT") in the /epics/ioc/MTest/iocBoot/iocMTest/st.cmd file
Can I edit / check? And what is that doing?
  st.cmd  code...
cd "/usr/local/epics/iocs/MTest/iocBoot/iocMTest"
< envPaths
< pvSettings
cd "$(TOP)"
dbLoadDatabase("dbd/MTest.dbd")
MTest_registerRecordDeviceDriver(pdbbase)
## Serial Configuration
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyAMA0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","19200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","odd")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
asynOctetSetInputEos("SERIALPORT",0,"\r")
asynOctetSetOutputEos("SERIALPORT",0,"\r")
MTestSetup(1,8,10)                        <-----------------here
MtestConfig(0,"SERIALPORT")             <-----------------here
## Load record instances
dbLoadRecords "db/motor_record.db","P=$(P),M=$(M1),S=0"
dbLoadRecords "db/motor_record.db","P=$(P),M=$(M2),S=1"
dbLoadRecords "db/motor_record.db","P=$(P),M=$(M3),S=2"
dbLoadRecords "db/motor_record.db","P=$(P),M=$(M4),S=3"
dbLoadRecords "db/motor_record.db","P=$(P),M=$(M5),S=4"
dbLoadRecords "db/motor_record.db","P=$(P),M=$(M6),S=5"
save_restoreSet_IncompleteSetsOk(1)
save_restoreSet_DatedBackupFiles(0)
set_requestfile_path("./")
set_savefile_path("./", "autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
cd "${TOP}/iocBoot/${IOC}"
iocInit
create_monitor_set("auto_settings.req", 30, "P=$(P),M1=$(M1),M2=$(M2),M3=$(M3),M4=$(M4),M5=$(M5)")
Question 2. ) It communicates via Rs232 with "raspberry Pi-> motor". I was curious about the communication,
                 so I changed it to "raspberry Pi-> PC com port".
  ./// output    PC terminal.
 % 01 # WCP8R08021R08121R08221R08321R08421R08521R08621R08721 **
% 01 # WCP8R08051R08151R08251R08351R08451R08551R08651R08751 **
% 01 # RCP3R0120R0121R0128 **
% 01 # RCP3R0122R0123R0129 **
% 01 # RCP3R0124R0125R012A **
% 01 # RCP3R0126R0127R012B **
% 01 # RCP3R0130R0131R0138 **
% 01 # RCP3R0132R0133R0139 **
These contents are printed out.
 Is this uart communication "where / who" control?
  I am studying and it is so difficult that I ask these basic questions. Please help me.
Thank you.
Prev: RE: EPICS release series after 7.0: 7.1 or 8.0? Abdalla Ahmad via Tech-talk
Next: Re: Ethernet question Hinko Kocevar via Tech-talk
Prev: Re: CA link question Benjamin Franksen via Tech-talk
Next: Re: "st.cmd" internal code question Mark Rivers via Tech-talk
