1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: EPICS release series after 7.0: 7.1 or 8.0?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 9 Jan 2020 09:59:51 +0100
On Wed, 8 Jan 2020 at 23:17, J. Lewis Muir via Tech-talk <[email protected]> wrote:
On 01/08, Johnson, Andrew N. wrote:
> We do try to be forward compatible with our APIs, so older code will
> generally compile and work on newer Base releases. There are times
> when we may break an API but if that happens deliberately we document
> that and show module developers how to change their code so it can be
> compiled against both the old and new APIs. If we do make an API change,
> code using the old API that needs to be modified should always break at
> compile-time, we don't want our users to find out they need to change
> their code after an upgrade when something doesn't work at 2am. We are
> very aware just how much out-of-tree support code is shared between the
> members of the EPICS collaboration, and most of the core developers have
> to maintain some of that either for the community of for their local
> site, so we see maintaining API compatibility as important.
That's positive.  Sorry to press more, but if EPICS adopted a semantic
versioning scheme, you'd have to increment the major version for *any*
incompatible API change.  But I'm sure the developers would make an
effort to avoid that by doing things differently, so it would likely not
be too big of a deal.
EPICS is less monolithic than it might look. Even the central parts called EPICS Base effectively always have been a distribution, i.e. a collection of modules - nowadays this shows in the source code structure (and on Linux in the library names), traditionally it didn't.
Are you really calling for the EPICS distribution version to do a <major> jump whenever any of its modules does an incompatible API change? Linux distributions certainly don't do this.
Don't get me wrong - I'm all for semantic versioning. I just don't know it this should even apply to a software collection version number.
Cheers,
~Ralph
Re: EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
Re: EPICS release series after 7.0: 7.1 or 8.0? Johnson, Andrew N. via Tech-talk
Prev: Re: EPICS release series after 7.0: 7.1 or 8.0? Wang Xiaoqiang via Tech-talk
Next: Re: Ethernet question Hinko Kocevar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
Next: Re: EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
