1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: [EXTERNAL] Lakeshore 336/360: how do I read the temperature
From: "Specht, Eliot via Tech-talk" <[email protected]>
To: "Pearson, Matthew R." <[email protected]>
Date: Wed, 15 Jan 2020 14:24:12 +0000
Matt,
Enabling the polling fixed the problem. Thanks for the quick response!
Eliot
-----Original Message-----
Sent: Tuesday, January 14, 2020 6:12 PM
To: Specht, Eliot <[email protected]>
Cc: [email protected]
Subject: Re: [EXTERNAL] Lakeshore 336/360: how do I read the temperature
Also, forgot to mention:
> should work, but this returns zero for all four indices. I think that the IOC has provisions (which I haven’t been able to follow) for assigning different sensors to different channels; do I need to do some assignments before I can read temperatures?
The database logic does link the output channels with input sensors, but it does this based on what’s configured on the controller so we don’t need to worry about it. The only reason this is done in the database logic is to change which temperature input link is used for the put_callback logic for each output (so that we’re waiting for the correct temperature to reach the setpoint when blocked via a put_callback).
Cheers,
Matt
Lakeshore 336/360: how do I read the temperature Specht, Eliot via Tech-talk
Re: [EXTERNAL] Lakeshore 336/360: how do I read the temperature Pearson, Matthew R. via Tech-talk
Prev: Re: EtherIP EPICS Support: Invalid Service 0x52 Kasemir, Kay via Tech-talk
Next: Re: Multiline statement in iocsh Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Lakeshore 336/360: how do I read the temperature Pearson, Matthew R. via Tech-talk
Next: Multiline statement in iocsh Saeed Haghtalab via Tech-talk
