1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Probelm with ethernet interface of Galil controller [DLM=For-Official-Use-Only]
From: "CLIFT, Mark via Tech-talk" <[email protected]>
Date: Sat, 18 Jan 2020 08:46:23 +0000
The problem reported in this case is interesting, since it appears very repeatable.  In that opening the full MEDM screen causes the problem.
To Galil users that have such a repeatable network issue.  In my experience Galil will fix the firmware if the customer provides a network "log" they can "play back" at their office to produce the error upon request.  To capture this log use this command.
set PATH=C:\Program Files\Wireshark;%PATH%
dumpcap -i "LabNetwork" -b filesize:10000 -b files:100 -w capture.pcapng
          The command is referenced at the link below:
           https://www.wireshark.org/docs/man-pages/dumpcap.html
          The -i switch is the name of your interface. The first -b sets up the circular buffer capturing files up to a certain            file size. The second one tell the buffer to rotate through n files. The -w is the base file name.
          Once you see the error, close the capture with CTRL+C.
Send the logs to Galil.  Recommend you try Troy Miller [email protected] who is their firmware expert.  If you have trouble finding the correct contact, let me know.  As a routine customer, I've worked with Galil for a while, and know some of the folks there.
Kind regards,
Prev: RE: PicoScope support? Loeher, Bastian Dr. via Tech-talk
Next: RE: Probelm with ethernet interface of Galil controller [DLM=For-Official-Use-Only] CLIFT, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Open positions at ITER Ralph Lange via Tech-talk
