1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: EPICS_CA_MCAST_TTL equivalent for pvAccess
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Michael Davidsaver via Tech-talk <[email protected]>, Denise Finstrom <[email protected]>
Cc: Jim Smedinghoff <[email protected]>
Date: Wed, 22 Jan 2020 20:10:02 +0000
PV Access _is_ using multicasts internally, basically as a replacement of the ca repeater.
When multiple servers and/or clients run on the same host, they pass the UDP messages which would by default only reach one of them to each other via a multicast.
For that, it makes sense to have a TTL of 1.
Would it hurt to send those with a larger TTL, when that enables using multicasts beyond localhost?
-Kay
From: Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
Sent: Wednesday, January 22, 2020 2:24 PM
To: Denise Finstrom <[email protected]>
Cc: Jim Smedinghoff <[email protected]>; [email protected] <[email protected]>
Subject: [EXTERNAL] Re: EPICS_CA_MCAST_TTL equivalent for pvAccess
On 1/22/20 8:18 AM, Denise Finstrom via Tech-talk wrote:
> Hello,
> Is there an equivalent to EPICS_CA_MCAST_TTL for the pvAccess protocol?
There isn't one.  PVA doesn't (yet) support search by mcast.
Were you able to make this work with CA?  What does your network topology look
like?  (how many hops)  Did you encounter any problems?
Adding this was a project of mine a few years ago.  I've actually never been
certain that it would work at scale since I don't have access to a large
network with mcast routing enabled for testing.  Nor have I had any feedback
from users until now.  So adding this feature to the PVA protocol code hasn't
been a priority for me.
> We are attempting to use multicast for PV search and haven't found a way to change TTL values when using pvAccess. When we set EPICS_PVA_ADDR_LIST to a multicast address, the multicast goes out with a TTL of one and doesn't get routed to other subnets. We are successfully using multicast for PV search with the CA protocol and EPICS_CA_MCAST_TTL. We are looking to do the same with pvAccess, but the EPICS_PVA_MCAST_TTL environment variable doesn't seem to exist. We are using base-7.0.3.1. Any advice would be appreciated.
> Thanks,
> Denise
Re: [EXTERNAL] Re: EPICS_CA_MCAST_TTL equivalent for pvAccess Michael Davidsaver via Tech-talk
EPICS_CA_MCAST_TTL equivalent for pvAccess Denise Finstrom via Tech-talk
Prev: Re: EPICS_CA_MCAST_TTL equivalent for pvAccess Michael Davidsaver via Tech-talk
Next: Re: [EXTERNAL] Re: EPICS_CA_MCAST_TTL equivalent for pvAccess Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
