Subject: XSPRESS3 hdf5 problems
From: John Dobbins via Tech-talk <[email protected]>
Date: Thu, 23 Jan 2020 14:15:21 +0000
All,
I have a new 5 channel Quantum Xspress3 data readout unit which when taking multiple frames will start generating hdf5 related error messages at what seems like random (will acquire between a few or thousands of frames before generating errors).  Once these messages start they seem to continue until the IOC segfaults.
repeating pair of error messages on the IOC console:
 HDF5-DIAG: Error detected in HDF5 (1.8.12) thread 0:
  #000: ../../src/H5Dio.c line 231 in H5Dwrite(): can't prepare for writing data
    major: Dataset
    minor: Write failed
  #001: ../../src/H5Dio.c line 348 in H5D__pre_write(): file selection+offset not within extent
    major: Dataspace
    minor: Out of range
This IOC is a binary that comes with the detector.
I have contacted Quantum.  I thought that while waiting to hear from them it would make sense to build an IOC from source. On github I see
epics-modules/xspress3
and
quantumdetectors/xspress3-epics  forked from the above.
Any advice on which i should go with? Any suspicions regarding the hdf5 errors?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Prev: RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Next: Re: EPICS support for PoE Injector Hub Konrad, Martin via Tech-talk
Prev: Re: Read/Write waveforms using Channel Access C API Ralph Lange via Tech-talk
Next: RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
