Subject: Re: ezca for 3.15
To: "Siddons, David" <[email protected]>
Date: Sat, 1 Feb 2020 22:13:46 +0000
Hi Peter,
You need this to add this line in your program:
#include <cadef.h>
before
#include <ezca.h>
Because ezca.h uses chid, it should really be including cadef itself.  But it doesn't.
Sent: Saturday, February 1, 2020 3:53 PM
To: Mark Rivers
Cc: tech-talk
Hi Mark,
   OK, I rebuilt my extensions directory, and built ezca. All went well. When I try to use ezca I hit problems. Here is my simple program; it reads a vector, changes one element and then writes it back:
#include <ezca.h>
main()
int d;
int s[384];
   ezcaGet("det1.TSEN", ezcaLong, 384, &s);
   ezcaGet("det1.CHAN",ezcaLong,1,&d);
   s[d]=1;
  ezcaPut("det1.TSEN", ezcaLong, 1, s);
and my compile line:
gcc -o testenable -L/home/peter/epics/extensions-master/lib -I/home/peter/epics/extensions-master/include -I//home/peter/epics/base-3.15.6/include/ -lezca testenable.c
which gets me:
In file included from testenable.c:1:0:
/home/peter/epics/extensions-master/include/ezca.h:77:61: error: unknown type name ‘chid’; did you mean ‘void’?
 epicsShareFunc int epicsShareAPI ezcaPvToChid(char *pvname, chid **cid);
                                                             void
/home/peter/epics/extensions-master/include/ezca.h:103:2: error: unknown type name ‘TS_STAMP’
  TS_STAMP *timestamp, short *status, short *severity);
/home/peter/epics/extensions-master/include/ezca.h:107:45: error: unknown type name ‘TS_STAMP’
  char ezcatype, int nelem, void *data_buff, TS_STAMP *timestamp,
testenable.c:2:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
 main()
So what am I doing wrong?
Pete.
Sent: Saturday, February 1, 2020 3:56 PM
To: Siddons, David <[email protected]>
Hi Pete,
I suspect you may be using an old version of ezca?  The latest version is here:
https://github.com/epics-extensions/extensions
<https://github.com:epics-extensions/extensions>
I just built successfully with that version on base 7.0.3.1, so I am pretty sure 3.15 will build fine as well.
Here is the output when building:
corvette:extensions_new/src/ezca>make
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/mkmf.pl  -m ezca.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           ezca.o ../ezca.c
make[1]: Leaving directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           -c ../ezca.c
../ezca.c: In function 'pop_channel':
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
    sizeof(struct channel)*NODESPERMAL, Channel_avail_hdr);
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_monitor':
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct monitor)*NODESPERMAL, Monitor_avail_hdr);
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_work':
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct work)*NODESPERMAL, Work_avail_hdr);
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
/usr/bin/ar -rc    libezca.a    ezca.o
/usr/bin/ranlib libezca.a
/usr/bin/g++ -o libezca.so -shared -fPIC -Wl,-hlibezca.so -L/usr/local/epics/extensions_new/lib/linux-x86_64 -L/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions_new/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-7.0.3.1/lib/linux-x86_64           -rdynamic -m64         ezca.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libezca.so
Installing library ../../../lib/linux-x86_64/libezca.a
Cheers,
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Saturday, February 1, 2020 2:33 PM
To: EPICS Tech Talk
Subject: ezca for 3.15
I want to use ezca with 3.15, but it seems to be a mess of missing header files, presumably things dropped with 3.15 (e.g. tsDefs.h, cadef.h). Has anyone made it work?
Pete.
Re: ezca for 3.15 Siddons, David via Tech-talk
Re: ezca for 3.15 Mark Rivers via Tech-talk
Prev: Re: ezca for 3.15 Siddons, David via Tech-talk
Next: Re: ezca for 3.15 Siddons, David via Tech-talk
