1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: areaDetector crashes EPICS IOC and autosave failure
To: 'Jong Woo Kim' <[email protected]>
Date: Tue, 4 Feb 2020 23:03:49 +0000
You did not give the path to the executable in your gdb command.  The syntax is:
gdb EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/bin/linux-x86_64/eigerDetectorApp coredump
You need to modify the path to include whatever goes before EPICS to specify an absolute path.  Or you can cd to the directory containing eigerDetectorApp and then type
gdb eigerDetectorApp /usr/lib/systemd/systemd-coredump
Sent: Tuesday, February 4, 2020 4:56 PM
Cc: [email protected]
Subject: Re: areaDetector crashes EPICS IOC and autosave failure
Hi Mark,
Thank you so much for letting me know. I could not find "core" in eigerDetectorApp or in any folder around it. Instead, I found systemd-coredump in  "/usr/lib/systemd/systemd-coredump".
The following is the result of running gdb and bt. It seems okay to me. Is this a wrong file?
$ gdb systemd-coredump
GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-115.el7
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
Reading symbols from /usr/lib/systemd/systemd-coredump...Reading symbols from /usr/lib/systemd/systemd-coredump...(no debugging symbols found)...done.
Missing separate debuginfos, use: debuginfo-install systemd-219-67.el7_7.2.x86_64
(gdb) bt
No stack.
Sent: Friday, January 31, 2020 4:56 PM
To: Jong Woo Kim <[email protected]>
Cc: [email protected] <[email protected]>
Hi Jong Woo,
Ø  $ gdb /path/to/ADEiger_executable core     --- > coredump doesn't work either
I was not clear in my instructions. “/path/to/ADEiger_executable” is not what you should type, you should type the actual path, which is probably something like:
EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/bin/linux-x86_64/eigerDetectorApp.
And “core” is the name of the actual core.* file that was created when you got the core dump message when the IOC crashed. It is probably in your iocBoot/iocEiger directory.  But on some systems it can be put in /var or somewhere else.
Sent: Friday, January 31, 2020 5:45 PM
Hi Mark,
Thank you so much. I resolved first two issues. But I'm still working on the last one 'eigerDetector crashes EPICS IOC'  ( e.i. Segmentation fault (core dumped) )
I wasn't able to find where it crashed. The following is the message I've got.
Note that the version of areaDetector, ADEiger, ADCore and EPICS base are R3-7, R2-7, R3-8, 3-15-6, respectively.
We're using FileWriter interface to save data files.
____________________________________________________________
/path/to/ADEiger_executable: No such file or directory.
.../EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/iocBoot/iocEiger/autosave/core: No such file or directory.
(gdb)
I researched for coredump files
.../systemd/coredump.conf
.../bin/coredumpctl
.../bin/systemd-coredumpctl
.../lib/systemd/systemd-coredump
.../share/bash-completion/completions/coredumpctl
.../share/man/man1/coredumpctl.1.gz
.../share/man/man5/coredump.conf.5.gz
.../share/man/man5/coredump.conf.d.5.gz
.../share/man/man8/systemd-coredump.8.gz
.../share/zsh/site-functions/_coredumpctl
.../include/config/coredump.h
.../include/config/dev/coredump.h
.../include/config/want/dev/coredump.h
.../include/linux/coredump.h
.../include/linux/devcoredump.h
.../lib/systemd/coredump
This is one of examples that results from gdb.
$ gdb /var/lib/systemd/coredump
<http://www.gnu.org/software/gdb/bugs/>...
/var/lib/systemd/coredump: Success.
Sent: Thursday, January 30, 2020 10:35 AM
Cc: Jong Woo Kim <[email protected]>; [email protected] <[email protected]>
Hi Jong Woo,
You have not told us what version of ADEiger, ADCore, EPICS base, etc. you are using.
Ø  a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message)
Did you uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugin_settings.req?
#file "sseqRecord_settings.req",     P=$(P),  S=AcquireSequence
If so you also need to uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugins.cmd
#set_requestfile_path("$(CALC)/calcApp/Db")
Ø  b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message)
Ø  ../save_restore.c(1774): [0xd]=write_it:Permission denied
That error seems pretty simple.  It is a file permission problem.  The files in that directory, or the directory itself, must not have write permission for the account that is running ADEiger application.  Fix the file permissions.
Ø  c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC (Red in the following message)
Ø  Actually data hasn't been collected
You have a core dump file.  You need to run gdb on that to find where it crashed.
Run this:
gdb /path/to/ADEiger_executable core.xxx
where core.xxx is the name of your core dump file.  Once you get the gdb> prompt type this command
backtrace
From: Tech-talk <[email protected]> On Behalf Of Jong Woo Kim via Tech-talk
Sent: Thursday, January 30, 2020 10:33 AM
To: [email protected]
Cc: Jong Woo Kim <[email protected]>; Jong Woo Kim <[email protected]>
Subject: areaDetector crashes EPICS IOC and autosave failure
Hello,
When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected.
In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message.
     I made sure that this file has contents and it is in a right folder
          support/calc-R3-7-3/calcApp/Db/sseq_settings.req
          support/calc-R3-7-3/db/sseq_settings.req
     It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't.
--------------------------------------------------- Message on monitor--------------------------------------------------------------
## EPICS R3.15.6
## EPICS Base built Dec  2 2019
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325'
save_restore: Can't write backup file.
2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR
EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate
Bad init_rec return value  PV: EIG1:cam1:FWClear ao: init_record
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
# Avoid deluge of messages when debugging
#dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P= EIG1:")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
epics> save_restore: Can't connect to all status PV(s)
auto_settings.sav: 1330 of 1330 PV's connected
save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357]
save_restore:write_save_file: Can't write save file. [200127-151357]
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427]
save_restore:write_save_file: Can't write save file. [200127-151427]
[iocEiger]$
Re: areaDetector crashes EPICS IOC and autosave failure Michael Davidsaver via Tech-talk
areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
RE: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Prev: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Next: Re: areaDetector crashes EPICS IOC and autosave failure Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
