To get a core dump out of systemd use the coredumpctl command.
See
man coredumpctl
or try
coredumpctl debug
> On Feb 4, 2020, at 4:56 PM, Jong Woo Kim via Tech-talk <[email protected]> wrote:
> Hi Mark,
> Thank you so much for letting me know. I could not find "core" in eigerDetectorApp or in any folder around it. Instead, I found systemd-coredump in "/usr/lib/systemd/systemd-coredump".
> The following is the result of running gdb and bt. It seems okay to me. Is this a wrong file?
> $ gdb systemd-coredump
> GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-115.el7
> Copyright (C) 2013 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law. Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-redhat-linux-gnu".
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>...
> Reading symbols from /usr/lib/systemd/systemd-coredump...Reading symbols from /usr/lib/systemd/systemd-coredump...(no debugging symbols found)...done.
> Missing separate debuginfos, use: debuginfo-install systemd-219-67.el7_7.2.x86_64
> (gdb) bt
> No stack.
> From: Mark Rivers <[email protected]>
> Sent: Friday, January 31, 2020 4:56 PM
> To: Jong Woo Kim <[email protected]>
> Cc: [email protected] <[email protected]>
> Subject: RE: areaDetector crashes EPICS IOC and autosave failure
> Hi Jong Woo,
> Ø $ gdb /path/to/ADEiger_executable core --- > coredump doesn't work either
> I was not clear in my instructions. “/path/to/ADEiger_executable” is not what you should type, you should type the actual path, which is probably something like:
> EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/bin/linux-x86_64/eigerDetectorApp.
> And “core” is the name of the actual core.* file that was created when you got the core dump message when the IOC crashed. It is probably in your iocBoot/iocEiger directory. But on some systems it can be put in /var or somewhere else.
> Mark
> From: Jong Woo Kim <[email protected]>
> Sent: Friday, January 31, 2020 5:45 PM
> To: Mark Rivers <[email protected]>
> Subject: Re: areaDetector crashes EPICS IOC and autosave failure
> Hi Mark,
> Thank you so much. I resolved first two issues. But I'm still working on the last one 'eigerDetector crashes EPICS IOC' ( e.i. Segmentation fault (core dumped) )
> I wasn't able to find where it crashed. The following is the message I've got.
> Note that the version of areaDetector, ADEiger, ADCore and EPICS base are R3-7, R2-7, R3-8, 3-15-6, respectively.
> We're using FileWriter interface to save data files.
> ____________________________________________________________
> /path/to/ADEiger_executable: No such file or directory.
> .../EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/iocBoot/iocEiger/autosave/core: No such file or directory.
> (gdb)
> I researched for coredump files
> .../systemd/coredump.conf
> .../bin/coredumpctl
> .../bin/systemd-coredumpctl
> .../lib/systemd/systemd-coredump
> .../share/bash-completion/completions/coredumpctl
> .../share/man/man1/coredumpctl.1.gz
> .../share/man/man5/coredump.conf.5.gz
> .../share/man/man5/coredump.conf.d.5.gz
> .../share/man/man8/systemd-coredump.8.gz
> .../share/zsh/site-functions/_coredumpctl
> .../include/config/coredump.h
> .../include/config/dev/coredump.h
> .../include/config/want/dev/coredump.h
> .../include/linux/coredump.h
> .../include/linux/devcoredump.h
> .../lib/systemd/coredump
> This is one of examples that results from gdb.
> $ gdb /var/lib/systemd/coredump
> /var/lib/systemd/coredump: Success.
> Sent: Thursday, January 30, 2020 10:35 AM
> Cc: Jong Woo Kim <[email protected]>; [email protected] <[email protected]>
> Hi Jong Woo,
> You have not told us what version of ADEiger, ADCore, EPICS base, etc. you are using.
> Ø a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message)
> Did you uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugin_settings.req?
> #file "sseqRecord_settings.req", P=$(P), S=AcquireSequence
> If so you also need to uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugins.cmd
> #set_requestfile_path("$(CALC)/calcApp/Db")
> Ø b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message)
> Ø ../save_restore.c(1774): [0xd]=write_it:Permission denied
> That error seems pretty simple. It is a file permission problem. The files in that directory, or the directory itself, must not have write permission for the account that is running ADEiger application. Fix the file permissions.
> Ø c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC (Red in the following message)
> Ø Actually data hasn't been collected
> You have a core dump file. You need to run gdb on that to find where it crashed.
> Run this:
> gdb /path/to/ADEiger_executable core.xxx
> where core.xxx is the name of your core dump file. Once you get the gdb> prompt type this command
> backtrace
> Mark
> From: Tech-talk <[email protected]> On Behalf Of Jong Woo Kim via Tech-talk
> Sent: Thursday, January 30, 2020 10:33 AM
> To: [email protected]
> Cc: Jong Woo Kim <[email protected]>; Jong Woo Kim <[email protected]>
> Subject: areaDetector crashes EPICS IOC and autosave failure
> Hello,
> When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected.
> In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message.
> I made sure that this file has contents and it is in a right folder
> support/calc-R3-7-3/calcApp/Db/sseq_settings.req
> support/calc-R3-7-3/db/sseq_settings.req
> It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't.
> --------------------------------------------------- Message on monitor--------------------------------------------------------------
> ## EPICS R3.15.6
> ## EPICS Base built Dec 2 2019
> reboot_restore: entry for file 'auto_settings.sav'
> reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
> *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
> save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325'
> save_restore: Can't write backup file.
> 2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR
> EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate
> Bad init_rec return value PV: EIG1:cam1:FWClear ao: init_record
> *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
> reboot_restore: done with file 'auto_settings.sav'
> iocRun: All initialization complete
> # Avoid deluge of messages when debugging
> #dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
> # save things every thirty seconds
> create_monitor_set("auto_settings.req", 30, "P= EIG1:")
> save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
> epics> save_restore: Can't connect to all status PV(s)
> auto_settings.sav: 1330 of 1330 PV's connected
> save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
> save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357]
> save_restore:write_save_file: Can't write save file. [200127-151357]
> save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427]
> save_restore:write_save_file: Can't write save file. [200127-151427]
> [iocEiger]$
- Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
- areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
- RE: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Re: areaDetector crashes EPICS IOC and autosave failure Michael Davidsaver via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
