I believe it silently sets the priority to 1 if it doesn't have permissions or is out of security limits. I remember an old bug that did something similar. Hopefully this helps. https://bugs.launchpad.net/epics-base/+bug/835138Hi,
I'm struggling to configure an IOC for real-time scheduling. To ensure
I/O and record processing are happening in a predictable way I want to
configure
- CPU affinity (core 1-3 for the IOC, core 0 for everything else)
- real-time scheduling (SCHED_FIFO for important threads)
- real-time priority (e.g. OS runs cbHigh thread with higher priority)
I read [1] but I need to tweak the instructions provided there a little
since my OS is using systemd which starts procServ which in turn
executes my IOC (standard FRIB configuration using the attached
service file). Systemd allows setting some RT properties. I'm adding the
following file to augment our standard configuration with a few RT settings:
/etc/systemd/system/softioc-masterioc.service.d/10-realtime.conf
[Service]
CPUAffinity = 1-3
CPUSchedulingPolicy=fifo
CPUSchedulingPriority=99
LimitMEMLOCK=infinity
I'm applying these changes to take them for a test drive:
$ sudo systemctl daemon-reload
$ sudo systemctl restart softioc-masterioc.service
Test CPU affinity:
$ taskset -c -p 1
pid 1's current affinity list: 0
$ taskset -c -p `pgrep st.cmd`
pid 6553's current affinity list: 1-3
Test memory lock:
Here comes the first surprise:
$ grep VmLck /proc/`pgrep st.cmd`/status
VmLck: 0 kB
After reading [2] I was expecting the IOC to call mlockall()
automatically. This apparently doesn't work. Linking my IOC against
mcore-utils and calling mcoreMLock() in st.cmd results in the memory
being locked, though:
VmLck: 2590972 kB
This suggest that the necessary permissions have been granted to the IOC
successfully. I'm suspecting that they might not be detected correctly
in my environment, though.
Test RT scheduling and priorities:
Here comes another surprise:
$ ps -To pid,tid,policy,rtprio,comm -p `pgrep st.cmd`
PID TID POL RTPRIO COMMAND
6553 6553 FF 99 st.cmd
6553 6555 FF 1 errlog
6553 6566 FF 1 PCIISR0000:08:0
6553 6567 FF 1 taskwd
6553 6568 FF 1 timerQueue
6553 6569 FF 1 cbLow
Apparently systemd configures the process to run with the correct RT
scheduling policy ("FF" aka SCHED_FIFO). It also sets the real-time
priority of the IOC process correctly. However, for some reason all
child threads seem to have a priority of 1 while I would expect them to
inherit the process' priority. I also tried to apply finer-grained
priorities using mcore-utils with the following rtrules file:
callbackThreads:*:*:1:cb.*
scanThreads:*:*:2:scan.*
stateMachines:*:50:3:snc.*
The rules are loaded successfully but both ps and mcoreThreadShowAll
still report RTPRIO/OSSPRI as "1" for all threads.
To rule out problems with my systemd configuration I replaced the IOC
executable with a little test program [3] with an endless loop. This
works as expected:
$ ps -To pid,tid,policy,rtprio,comm -p `pgrep a.out`
19737 19737 FF 99 a.out
19737 19738 FF 80 a.out
Am I using EPICS' RT features the wrong way?
Martin
P.S.: My system runs Debian 10 with Debian's RT kernel:
$ uname -a
Linux gts-fts-mstr-n0001 4.19.0-6-rt-amd64 #1 SMP PREEMPT RT Debian
4.19.67-2+deb10u1 (2019-09-20) x86_64 GNU/Linux
[1]
https://epics-controls.org/resources-and-support/documents/howto-documents/posix-thread-priority/
[2] https://epics.anl.gov/base/R3-15/7-docs/RELEASE_NOTES.html
[3]
https://wiki.linuxfoundation.org/realtime/documentation/howto/applications/application_base#example
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
- Real-time IOC and systemd Konrad, Martin via Tech-talk
SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
<2020>
2025
2026
Re: Real-time IOC and systemd Benjamin Franksen via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
