motorApp/Db/asyn_motor.db contains these 3 records (in addition to others). These are all you need to get the motor record resolution, offset, and direction fields into your driver.
# Motor direction for this axis
record(longout,"$(P)$(M)Direction") {
field(DESC, "$(M) direction")
field(DOL, "$(P)$(M).DIR CP MS")
field(OMSL, "closed_loop")
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT),$(ADDR))MOTOR_REC_DIRECTION")
# Motor offset for this axis
record(ao,"$(P)$(M)Offset") {
field(DESC, "$(M) offset")
field(DOL, "$(P)$(M).OFF CP MS")
field(DTYP, "asynFloat64")
field(OUT, "@asyn($(PORT),$(ADDR))MOTOR_REC_OFFSET")
field(PREC, "$(PREC)")
# Motor resolution for this axis
record(ao,"$(P)$(M)Resolution") {
field(DESC, "$(M) resolution")
field(DOL, "$(P)$(M).MRES CP MS")
field(OUT, "@asyn($(PORT),$(ADDR))MOTOR_REC_RESOLUTION")
This is how the Newport XPS driver gets these values.
> And even there: MOTOR_REC_RESOLUTION was unknown, I had to change it to MOTOR_RESOLUTION in the OUT field. Probably a version issue.
No, it is not a version issue. MOTOR_REC_RESOLUTION is defined in asynMotorController.h. It is different from MOTOR_RESOLUTION. MOTOR_REC_RESOLUTION is the MRES field of the motor record.
corvette:~/devel/motor/include>find . -name '*.h' -exec grep -H -i motorrecresolution {} \;
./asynMotorController.h:#define motorRecResolutionString "MOTOR_REC_RESOLUTION"
./asynMotorController.h: int motorRecResolution_;
> This exhibited some surprising (to me) features. Or shall I call it bugs?
Please load that provided database and see if you have problems. I am not convinced there are bugs, just a lack of documentation.
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Koennecke Mark (PSI) via Tech-talk
Sent: Wednesday, February 12, 2020 4:06 AM
To: tech-talk at aps.anl.gov
Subject: asynMotorAxis
I finally managed to get the resolution down into my my motor driver. It was an interesting experience. It was NOT enough to implement writeFloat64(). The resolution did not arrive.
I had it print to me what it was doing and this was interesting:
- On initialization I got a code motorEncResolution_ with infinity value. Obviously not yet initialized.
- No motorResolution_
- When I tried to manually set MRES, I received motorPosition_ function codes with a newly calculated
position. No motorResolution_.
I had to use Giles Knap suggestion with the additional DB field too in order to achieve success. And even
Thanks and Best Regards,
Mark Koennecke
- asynMotorAxis Koennecke Mark (PSI) via Tech-talk
RE: send/receive waveform over network. Mark Rivers via Tech-talk
<2020>
2025
Real-time IOC and systemd Konrad, Martin via Tech-talk
<2020>
2025
