1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: EPICS Archiver appliance MySQL Persistence error
From: Peter Linardakis via Tech-talk <[email protected]>
Date: Thu, 20 Feb 2020 05:14:53 +0000
Hi all
Attempted to build a single machine installation of an EPICS archiver appliance using the install_scripts/single_machine_install.sh script.  Everything seemed to go OK with the install and the management URL displays correctly, except there are errors as below, which also show when you attempt to add a PV.  The MySQL daemon is running and I have added a connection pool to conf/contect.xml as per https://slacmshankar.github.io/epicsarchiver_docs/installguide.html (although the error is identical without it).
mysql-connector-java-8.0.19.jar is installed under /opt/archappl/tomcatinstances/apache-tomcat-9.0.31/lib/
…/mgmt/logs/arch.log
0    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Archiver Appliance Version 0.0.1_SNAPSHOT_13-November-2019T15-45-42
1    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
28   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://nucserver4:17665/mgmt/bpl
29   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties from the webapp classpath /opt/archappl/tomcatinstances/mgmt/webapps/mgmt/WEB-INF/classes/archappl.properties
30   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/tomcatinstances/mgmt/webapps/mgmt/WEB-INF/classes/archappl.properties
11333 [Startup executor] INFO  config.org.epics.archiverappliance.config.persistence.MySQLPersistence  - Looking up datasource called jdbc/archappl in the java:/comp/env namespace using JDNI
11334 [Startup executor] INFO  config.org.epics.archiverappliance.config.persistence.MySQLPersistence  - Found datasource called jdbc/archappl in the java:/comp/env namespace using JDNI
11335 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading PVTypeInfo from persistence
11347 [Startup executor] ERROR config.org.epics.archiverappliance.config.DefaultConfigService  - Exception loading PVs from persistence java.io.IOException: java.sql.SQLException: Cannot create JDBC driver of class '' for connect URL 'null'
        at org.epics.archiverappliance.config.persistence.MySQLPersistence.getKeys(MySQLPersistence.java:145)
        at org.epics.archiverappliance.config.persistence.MySQLPersistence.getTypeInfoKeys(MySQLPersistence.java:51)
Relevant lines form the startup file are:
export JAVA_HOME=/usr/lib/jvm/jdk-13.0.2
export TOMCAT_HOME=/opt/archappl/tomcatinstances/apache-tomcat-9.0.31
export ARCHAPPL_DEPLOY_DIR=/opt/archappl/tomcatinstances
export ARCHAPPL_APPLIANCES=/opt/archappl/tomcatinstances/appliances.xml
export ARCHAPPL_MYIDENTITY="appliance0"
Am I missing something basic?
Regards
Peter
Dr Peter Linardakis
Senior Accelerator R&D Engineer
Nuclear Physics | Research School of Physics
Australian National University
Re: EPICS Archiver appliance MySQL Persistence error Heinz Junkes via Tech-talk
Prev: RE: matrix multiplication and inversions [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Next: MEMD is stuck on windows-x64 杨栋亮 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: EPICS Archiver appliance MySQL Persistence error Heinz Junkes via Tech-talk
