1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Problem in installing synApps_6_0
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Kim SeongBin <[email protected]>
Date: Mon, 24 Feb 2020 17:13:16 +0000
I think you probably need to edit configure/CONFIG_SITE, and uncomment the line
# TIRPC=YES
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Kim SeongBin via Tech-talk <[email protected]>
Sent: Monday, February 24, 2020 3:00 AM
To: [email protected] <[email protected]>
Subject: Problem in installing synApps_6_0
I am using the Fedora 28.
I am facing the following error messages when installing synApps_6_0 with EPICS base 3.15.5.
Please help me.
Seongbin Kim
gmake -C asyn/asynPortDriver/unittest install
gmake[1]: Entering directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest'
perl -CSD /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir O.Common
gmake -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 install
gmake[2]: Entering directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic
 -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include
 -I/usr/local/epics/extensions/src/synApps_6_0/support//ipac-2-15/include   -I/usr/local/epics/extensions/src/synApps_6_0/support//seq-2-2-5/include
 -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include
 -MM -MF asynPortDriverTest.d  ../asynPortDriverTest.cpp
 -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include        -c ../asynPortDriverTest.cpp
/usr/bin/g++ -o asynPortDriverTest  -L/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64
 -L/usr/local/epics/base-3.15.5/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64 -Wl,
-rpath,/usr/local/epics/base-3.15.5/lib/linux-x86_64           -rdynamic -m64            asynPortDriverTest.o    -lasyn -lCom
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bytes'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_free'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_sperror'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bool'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_int'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_spcreateerror'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_string'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_void'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_enum'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `clnttcp_create'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_char'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_int'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_short'
/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_char'
collect2: error: ld returned 1 exit status
gmake[2]: *** [/usr/local/epics/base/configure/RULES_BUILD:202: asynPortDriverTest] Error 1
gmake[2]: Leaving directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest/O.linux-x86_64'
gmake[1]: *** [/usr/local/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
gmake[1]: Leaving directory '/usr/local/epics/extensions/src/synApps_6_0/support/asyn-R4-33/asyn/asynPortDriver/unittest'
gmake: *** [/usr/local/epics/base/configure/RULES_DIRS:84: asyn/asynPortDriver/unittest.install] Error 2
Re: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
Prev: Re: firewalld configuration for EPICS? Gabriel Fedel via Tech-talk
Next: asyn R4-39 available Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
Next: Re: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
