1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: New versions of ADGenICam, ADPointGrey, ADPilatus released
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 25 Feb 2020 16:39:45 +0000
Folks,
New releases of the following areaDetector modules are now available.
ADGenICam R1-3
ADPointGrey R2-9
ADPilatus R2-9
This is from the release notes for ADGenICam:
R1-3 (24-February-2020)
* Fix an error when creating the enum choices for GenICam features that are not writable.
  This cause the readback value to be invalid because it was not one of the allowed enum values.
  This generated errors in medm (and probably other OPIs) when opening screens containing these records.
* Added xml, template, and OPI files for a number of additional Allied Vision Technologies/Prosilica
  and FLIR/Point Grey cameras.
* Fixed addCamera.sh to specify that Python 3 should be used.
* Added autoconverted .bob files for Phoebus Display Manager.
This is from the release notes for ADPointGrey:
R2-9 (24-February-2020)
* Added new ResendEnable record to control whether GigE packets should be resent on error.
  Thanks to Oksana Ivashkevych for this.
* Converted documentation to .rst files on areaDetector.github.io.
* Added .bob files for Phoebus Display Manager
This is from the release notes for ADPilatus:
* Fixed driver to move array counter increment to before setting NDArray UniqueId.
* Changed documentation to .rst files on areaDetector.github.io.
https://github.com/areaDetector
Prev: RE: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
Next: error in 'make' during installation of areaDetector Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: areaDetector and ADCore R3-9 released Mark Rivers via Tech-talk
ANJ, 25 Feb 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
