1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: error in 'make' during installation of areaDetector
To: 'Jong Woo Kim' <[email protected]>
Date: Wed, 26 Feb 2020 00:13:27 +0000
Hi Jong Woo,
Ø  After modification of configure files, I ran 'make'. But the following message came out.
Did you modify the following files in areaDetector/configure:
RELEASE_LIBS.local (to set paths to base, SUPPORT, asyn, etc.)
RELEASE_PRODS.local (to set paths to base, SUPPORT, asyn, etc.)
CONFIG_SITE.local (to change build options)
RELEASE.local (to control what gets built)
What directory were you in when you typed “make”?  You should be in the top-level areaDetector directory.
Please send the complete output of “make” and your RELEASE_LIBS.local and RELEASE_PRODS.local files.
From: Tech-talk <[email protected]> On Behalf Of Jong Woo Kim via Tech-talk
Sent: Tuesday, February 25, 2020 6:01 PM
To: [email protected]
Subject: error in 'make' during installation of areaDetector
Hello,
Via 'git clone', I installed 'areaDetector' under [synApps_6_1/support], and 'ADCore', 'ADsupport' and 'ADEiger' below it.
_________________________________________________________
configure/CONFIG:17: /configure/CONFIG: No such file or directory
configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
make: *** No rule to make target `/configure/RULES_TOP'.  Stop.
It would be appreciated, if you give me a feedback.
Best,
Jong Woo
Re: error in 'make' during installation of areaDetector Jong Woo Kim via Tech-talk
Prev: error in 'make' during installation of areaDetector Jong Woo Kim via Tech-talk
Next: Re: error in 'make' during installation of areaDetector Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
