1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: defining a path of PVA for EPICS base 3.x
From: Matic Pogacnik via Tech-talk <[email protected]>
To: Jong Woo Kim <[email protected]>
Cc: [email protected]
Date: Tue, 3 Mar 2020 20:22:15 +0100 (CET)
EPICS V3 doesn’t include V4 modules. They must be downloaded separately from http://epics-pvdata.sourceforge.net/index.html (https://sourceforge.net/projects/epics-pvdata/files/ )
Best regards,
Matic
----- Original Message -----
From: "Jong Woo Kim via Tech-talk" <[email protected]>
To: [email protected]
Sent: Tuesday, March 3, 2020 7:57:03 PM
Subject: defining a path of PVA for EPICS base 3.x
I am using the following versions.
EPICS base-3.15.6
asyn4-37
areaDetector-R3-9
ADCore-R3-9
There is a way to define the path of 'PVA' for those who use prior to EPICS base 7.
The following shows an example for EPICS V4. I couldn't find a corresponding folder or files in EPICS base-3.15.6.
Do I have to upgrade?
_________________________________________________________________________
# If CONFIG_SITE.local defines WITH_PVA=YES and EPICS_BASE is prior to 7.0 then define the path here
# If using EPICS_BASE 7.0 or later the PVA files are in base itself and no additional definitions are needed.
#PVA=/corvette/usr/local/epics-devel/epicsV4/EPICS-CPP-4.6.0
# PVA modules
# For versions prior to EPICS base 7.0 use this
#PVCOMMON=$(PVA)/pvCommonCPP
#PVACCESS=$(PVA)/pvAccessCPP
#PVDATA=$(PVA)/pvDataCPP
#PVDATABASE=$(PVA)/pvDatabaseCPP
#NORMATIVETYPES=$(PVA)/normativeTypesCPP
-include $(AREA_DETECTOR)/configure/RELEASE_LIBS.local.$(EPICS_HOST_ARCH)
Re: defining a path of PVA for EPICS base 3.x Johnson, Andrew N. via Tech-talk
Re: defining a path of PVA for EPICS base 3.x Michael Davidsaver via Tech-talk
defining a path of PVA for EPICS base 3.x Jong Woo Kim via Tech-talk
Prev: defining a path of PVA for EPICS base 3.x Jong Woo Kim via Tech-talk
Next: Re: defining a path of PVA for EPICS base 3.x Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
