Subject: CA output links not working with PINI=YES?
From: Christoph Schroeder via Tech-talk <[email protected]>
Date: Thu, 5 Mar 2020 11:52:38 +0100
Hello everyone,
I need to write a value via CA link on IOC boot which didn't seem to
work with PINI=YES.
I created a minimal example to investigate this:
Source:
record (longout, "TEST:longout") {
    field(OUT, "TEST:longin CA")
    field(VAL, "1")
    field(PINI, "YES")
Target:
record (longin, "TEST:longin") {
The documentation states, that the target fields PP attribute decides
whether to process the record or not for CA output links. This is the
case for the longin's VAL field:
field(VAL, DBF_LONG) {
    pp(TRUE)
    promptgroup("40 - Input")
    asl(ASL0)
    prompt("Current value")
What's strange is, that the CA link is invalid after initialization:
TEST:longout                   2020-03-05 10:34:03.097922 1 LINK INVALID
Of course I started the IOC running TEST:longin beforehand.
Processing TEST:longout afterwards will work as intended. Am I missing
something or do CA output links do not work on initialization in general?
I tested this with base R3.15.5 and base R7.0.2.1 whith two IOCs running
on the same machine, same behavior for both.
Thanks and best regards,
Christoph
(bb|[^b]{2})
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Prev: Re:RE: Asyn support for GPIB-ENET 杨栋亮 via Tech-talk
Next: Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Prev: Re: String size limit for Eiger FileWriter when compiling with g++ > 5.2 Bruno Martins via Tech-talk
