I still want to open the .edl-Screens usind EDM. But the compiling of DM fails with following errors when it comes to /extensions/src/edm/giflib:
make[1]: Leaving directory '/soft/epics/extensions/src/edm/edmMain'
I'm on an OpenSuse Leap 15.1. In the EDM readme.install it says:
make -C ./giflib install make[1]: Entering directory '/soft/epics/extensions/src/edm/giflib' make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \ T_A=linux-x86_64 install make[2]: Entering directory '/soft/epics/extensions/src/edm/giflib/O.linux-x86_64' /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -std=c++0x -fpermissive -Wno-narrowing -Wno-write-strings -Wno-unused-but-set-variable -DSINGLE_THREADED=1 -D__epics__=1 -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/edm/compiler/gcc -I../../../../include/edm/os/Linux -I../../../../include/edm -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include -I/soft/epics/extensions/include -I../../util -I../../lib -I/usr/include -I/usr/include -c ../gif.cc ../gif.cc: In member function ‘int activeGifClass::readGifFile()’: ../gif.cc:24:50: error: too few arguments to function ‘GifFileType* DGifOpenFileName(const char*, int*)’ #define GIF_OPEN_FILE(gif) DGifOpenFileName(gif) ^ ../gif.cc:442:11: note: in expansion of macro ‘GIF_OPEN_FILE’ gif = GIF_OPEN_FILE( name ); ^~~~~~~~~~~~~ In file included from ../gif.h:28:0, from ../gif.cc:39: /usr/include/gif_lib.h:179:14: note: declared here GifFileType *DGifOpenFileName(const char *GifFileName, int *Error); ^~~~~~~~~~~~~~~~ ../gif.cc:23:48: error: too few arguments to function ‘int DGifCloseFile(GifFileType*, int*)’ #define GIF_CLOSE_FILE(gif) DGifCloseFile(gif) ^ ../gif.cc:898:12: note: in expansion of macro ‘GIF_CLOSE_FILE’ status = GIF_CLOSE_FILE( gif ); ^~~~~~~~~~~~~~ In file included from ../gif.h:28:0, from ../gif.cc:39: /usr/include/gif_lib.h:183:9: note: declared here int DGifCloseFile(GifFileType * GifFile, int *ErrorCode); ^~~~~~~~~~~~~ ../gif.cc:23:48: error: too few arguments to function ‘int DGifCloseFile(GifFileType*, int*)’ #define GIF_CLOSE_FILE(gif) DGifCloseFile(gif) ^ ../gif.cc:910:30: note: in expansion of macro ‘GIF_CLOSE_FILE’ if ( fileOpened ) status = GIF_CLOSE_FILE( gif ); ^~~~~~~~~~~~~~ In file included from ../gif.h:28:0, from ../gif.cc:39: /usr/include/gif_lib.h:183:9: note: declared here int DGifCloseFile(GifFileType * GifFile, int *ErrorCode); ^~~~~~~~~~~~~ make[2]: *** [/soft/epics/base-3.15.7/configure/RULES_BUILD:236: gif.o] Error 1 make[2]: Leaving directory '/soft/epics/extensions/src/edm/giflib/O.linux-x86_64' make[1]: *** [/soft/epics/base-3.15.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 make[1]: Leaving directory '/soft/epics/extensions/src/edm/giflib' make: *** [/soft/epics/base-3.15.7/configure/RULES_DIRS:84: giflib.install] Error 2 bam01:/soft/epics/extensions/src/edm #
Von: Sintschuk, Michael
Gesendet: Mittwoch, 4. März 2020 16:53:17 An: Mark Rivers; Bradnick, Ben (Tessella,RAL,TEC); Ivashkevych, Oksana Cc: tech-talk Betreff: AW: pco Camera USB and IEEE interface >That is done with the areaDetector file saving plugins. There should be a screen on which you can open the plugins. If not you can load ADBase.opi for that camera and then there will be screens for all of the plugins. There are file saving plugins for TIFF, JPEG, netCDF, HDF5, and others.
Yes, that worked, thanks! Oksana mentioned that in her previous answer but I missed it.
Von: Mark Rivers <[email protected]>
Gesendet: Mittwoch, 4. März 2020 14:32:04 An: Bradnick, Ben (Tessella,RAL,TEC); Ivashkevych, Oksana; Sintschuk, Michael Cc: tech-talk Betreff: Re: pco Camera USB and IEEE interface > The only thing that is left: where are the images stored? And is there a way to select the image-format: TIFF, JPEG, something else? That is done with the areaDetector file saving plugins. There should be a screen on which you can open the plugins. If not you can load ADBase.opi for that camera and then there will be screens for all of the plugins. There are file saving plugins for TIFF, JPEG, netCDF, HDF5, and others. > I suppose that I need to compile the areaDetector Viewers module and connect that somehow to my camera IOC, right? Using ImageJ would be great! You don't really compile that module since the viewers are written in ImageJ, Python, and IDL. For the ImageJ plugins you do compile the Java code, but that is done from the ImageJ window. Mark ________________________________ From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]> Sent: Wednesday, March 4, 2020 6:55 AM To: Bradnick, Ben (Tessella,RAL,TEC); Mark Rivers via Tech-talk; Ivashkevych, Oksana Subject: AW: pco Camera USB and IEEE interface Hello all, I changed the line: # pcoConfig(const char* portName, int maxBuffers, size_t maxMemory) pcoConfig("PCO1", 0, 0, 8) to pcoConfig("PCO1", 0, 0, 14) and now there is no warning, just the message: Found 14 devices on camera. With the help of Oksanas description of CSS I can now open the OPIs for camera control: - pcoDetector_conn.opi (everything connected, ok) - pcoDetectorPerformance.opi (everything connected, ok) - pcoSingleDeviceFW.opi (everything connected, ok) - pcowin_embed.opi (everything connected, I can start/stop acquire images) In the pcoDetectorMore.opi not everything is connected: the box "PCO ganging" shows the message "This PCO IOC does not support gang mode". Don't know what that means... And in the box "PCO Hardware Sync Signals" nothing is connected (dont know if I even need that). The only thing that is left: where are the images stored? And is there a way to select the image-format: TIFF, JPEG, something else? I suppose that I need to compile the areaDetector Viewers module and connect that somehow to my camera IOC, right? Using ImageJ would be great! Best regards, Michael ________________________________ Von: Bradnick, Ben (Tessella,RAL,TEC) <[email protected]> Gesendet: Dienstag, 3. März 2020 10:44:06 An: Mark Rivers via Tech-talk; Sintschuk, Michael Cc: Mark Rivers via Tech-talk Betreff: Re: pco Camera USB and IEEE interface Hi Mark, Michael, The warning about the limit of 8 devices can be ignored. This is related to getting the firmware information from all of the camera "devices" but the number of devices varies between PCO models and isn't known until it queries the camera. This doesn't affect functionality at all - I should change the message as it looks misleading. The 8 from the boot script sets the number of camera devices to query the firmware information for: # pcoConfig(const char* portName, int maxBuffers, size_t maxMemory) pcoConfig("PCO1", 0, 0, 8) The driver is just complaining that there are a total of 14 devices on that specific camera, and it can't store the firmware information for each of them. Kind regards, Ben ________________________________ From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]> Sent: 02 March 2020 14:32 To: Sintschuk, Michael <[email protected]>; Ivashkevych, Oksana <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: pco Camera USB and IEEE interface Hi Michael, > For the future: should I use the _dynamic build or can I stay with static? Is there any difference for me? The advantage of static is that if you want to run the IOC on another machine without the EPICS build system, there is just the single .exe file to copy. You don't need to worry about copying dozens of EPICS DLLs and making sure they are found at run time. The downside is that the executable is a lot bigger and takes longer to link, but those are not very important factors. I don't know the answer to your question about launching CSS with a standalone window, or the message about the limit of 8 devices. Mark ________________________________ From: Sintschuk, Michael <[email protected]> Sent: Monday, March 2, 2020 8:17 AM To: Ivashkevych, Oksana; Mark Rivers Cc: [email protected] Subject: AW: pco Camera USB and IEEE interface >I have fixed the problems with dynamic builds of ADPcoWin. There is a fix_dynamic branch on Github and a pull request >pending for master. For the future: should I use the _dynamic build or can I stay with static? Is there any difference for me? Concerning my edm struggle: >If you send the errors we can probably help figure them out. I think I first stay with CSStudio mentioned by Oksana. I managed to open the .opi screens with that, but only inside of the whole studio programm and not as a standalone window. How can I open that and give my PVs from console like: start medm -x -macro "P=13PCO1:, R=cam1:" pointGrey.adl & And this is how my IOC-startup looks like: (the PCO.1600 is connected via USB) PS C:\epics\inst-7.0.3.1\areaDetector-R3-9\ADPcoWin\iocs\pcowinIOC\iocBoot\iocPco1600Win> C:\epics\inst-7.0.3.1\a reaDetector-R3-9\ADPcoWin\iocs\pcowinIOC\bin\windows-x64-static\pcowinApp.exe .\st.cmd < envPaths epicsEnvSet("IOC","iocPco1600Win") epicsEnvSet("TOP","C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC") epicsEnvSet("ADPCOWIN","C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../..") epicsEnvSet("SUPPORT","C:/epics/inst-7.0.3.1") epicsEnvSet("ASYN","C:/epics/inst-7.0.3.1/asyn-R4-39") epicsEnvSet("AREA_DETECTOR","C:/epics/inst-7.0.3.1/areaDetector-R3-9") epicsEnvSet("ADSUPPORT","C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADSupport") epicsEnvSet("ADCORE","C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore") epicsEnvSet("AUTOSAVE","C:/epics/inst-7.0.3.1/autosave-R5-10") epicsEnvSet("BUSY","C:/epics/inst-7.0.3.1/busy-R1-7-2") epicsEnvSet("CALC","C:/epics/inst-7.0.3.1/calc-R3-7-3") epicsEnvSet("SSCAN","C:/epics/inst-7.0.3.1/sscan-R2-11-3") epicsEnvSet("EPICS_BASE","C:/epics/base-7.0.3.1") errlogInit(20000) dbLoadDatabase("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/dbd/pcowinApp.dbd") pcowinApp_registerRecordDeviceDriver(pdbbase) # PREFIX for all records epicsEnvSet("PREFIX", "PCO1600:") # The port name for the detector epicsEnvSet("PORT", "PCO1") # Larger queue size may be need to stream to disk at full camera speed, up tp 2000 epicsEnvSet("QSIZE", "20") # The maximim image width; used for row profiles in the NDPluginStats plugin epicsEnvSet("XSIZE", "2560") # The maximim image height; used for column profiles in the NDPluginStats plugin epicsEnvSet("YSIZE", "2160") # The maximum number of time series points in the NDPluginStats plugin epicsEnvSet("NCHANS", "2048") # The maximum number of frames buffered in the NDPluginCircularBuff plugin epicsEnvSet("CBUFFS", "500") # The search path for database files epicsEnvSet("EPICS_DB_INCLUDE_PATH", "C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db") # Define NELEMENTS to be enough for a 2048x2048x3 (color) image epicsEnvSet("NELEMENTS", "11059200") # pcoConfig(const char* portName, int maxBuffers, size_t maxMemory) pcoConfig("PCO1", 0, 0, 8) # pcoApiConfig(const char* portName) pcoApiConfig("PCO1") # Asyn tracing asynSetTraceIOMask(PCO1, 0, 2) #asynSetTraceMask($(PORT), 0, 0xFF) #asynSetTraceFile($(PORT), 0, "asynTrace.out") #asynSetTraceInfoMask($(PORT), 0, 0xf) dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco.template", "P=PCO1600:,R=cam 1:,PORT=PCO1,ADDR=0,TIMEOUT=1") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=0") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=1") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=2") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=3") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=4") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=5") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=6") dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../db/pco_device_firmware.template", " P=PCO1600:,R=cam1:,PORT=PCO1,N=7") # What other database files need to be loaded? # Create a standard arrays plugin NDStdArraysConfigure("Image1", 5, 0, "PCO1", 0, 0) # Use this line for 8-bit data only dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDStdArrays.template", "P=PCO1600:,R=image1:,PORT=Image 1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1,TYPE=Int8,FTVL=CHAR,NELEMENTS=11059200") # Use this line for 8-bit or 16-bit data dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDStdArrays.template", "P=PCO1600:,R=image1:,PORT=Image 1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1,TYPE=Int16,FTVL=SHORT,NELEMENTS=11059200") # Use this line for 8-bit, 16-bit, or 32-bit data #dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(P ORT),TYPE=Int32,FTVL=LONG,NELEMENTS=$(NELEMENTS)") # Load all other plugins using commonPlugins.cmd < C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/iocBoot/commonPlugins.cmd # This is an example file for creating plugins # It uses the following environment variable macros # Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being # use the autosave value will replace the value passed to this file. # $(PREFIX) Prefix for all records # $(PORT) The port name for the detector. In autosave. # $(QSIZE) The queue size for all plugins. In autosave. # $(XSIZE) The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT # profiles in NDPluginFFT. # $(YSIZE) The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin # $(NCHANS) The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins # $(CBUFFS) The maximum number of frames buffered in the NDPluginCircularBuff plugin # $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5. # Create a netCDF file saving plugin NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "PCO1", 0) dbLoadRecords("NDFileNetCDF.template","P=PCO1600:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create a TIFF file saving plugin NDFileTIFFConfigure("FileTIFF1", 20, 0, "PCO1", 0) dbLoadRecords("NDFileTIFF.template", "P=PCO1600:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create a JPEG file saving plugin NDFileJPEGConfigure("FileJPEG1", 20, 0, "PCO1", 0) dbLoadRecords("NDFileJPEG.template", "P=PCO1600:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create a NeXus file saving plugin NDFileNexusConfigure("FileNexus1", 20, 0, "PCO1", 0) dbLoadRecords("NDFileNexus.template", "P=PCO1600:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create an HDF5 file saving plugin NDFileHDF5Configure("FileHDF1", 20, 0, "PCO1", 0) dbLoadRecords("NDFileHDF5.template", "P=PCO1600:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=PCO1" ) # Create a Magick file saving plugin #NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0) #dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Create 4 ROI plugins NDROIConfigure("ROI1", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=PCO1600:,R=ROI1:, PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") NDROIConfigure("ROI2", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=PCO1600:,R=ROI2:, PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") NDROIConfigure("ROI3", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=PCO1600:,R=ROI3:, PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") NDROIConfigure("ROI4", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=PCO1600:,R=ROI4:, PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create 8 ROIStat plugins NDROIStatConfigure("ROISTAT1", 20, 0, "PCO1", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDROIStat.template", "P=PCO1600:,R=ROIStat1: ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1,NCHANS= 2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=PCO1600:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048") # Create a processing plugin NDProcessConfigure("PROC1", 20, 0, "PCO1", 0, 0, 0) dbLoadRecords("NDProcess.template", "P=PCO1600:,R=Proc1:, PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create a TIFF file plugin to read dark and flatfield images into the processing plugin NDFileTIFFConfigure("PROC1TIFF", 20, 0, "PCO1", 0) dbLoadRecords("NDFileTIFF.template", "P=PCO1600:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create a scatter plugin NDScatterConfigure("SCATTER1", 20, 0, "PCO1", 0, 0, 0) dbLoadRecords("NDScatter.template", "P=PCO1600:,R=Scatter1:, PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create a gather plugin with 8 ports NDGatherConfigure("GATHER1", 20, 0, 8, 0, 0) dbLoadRecords("NDGather.template", "P=PCO1600:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDGatherN.template", "P=PCO1600:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create 5 statistics plugins NDStatsConfigure("STATS1", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=PCO1600:,R=Stats1:, PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2560,YSIZ E=2160,NCHANS=2048,NDARRAY_PORT=PCO1") NDTimeSeriesConfigure("STATS1_TS", 20, 0, "STATS1", 1, 23) dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDTimeSeries.template", "P=PCO1600:,R=Stats1:TS:, PORT =STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS2", 20, 0, "ROI1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=PCO1600:,R=Stats2:, PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2560,YSIZ E=2160,NCHANS=2048,NDARRAY_PORT=PCO1") NDTimeSeriesConfigure("STATS2_TS", 20, 0, "STATS2", 1, 23) dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDTimeSeries.template", "P=PCO1600:,R=Stats2:TS:, PORT =STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS3", 20, 0, "ROI2", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=PCO1600:,R=Stats3:, PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2560,YSIZ E=2160,NCHANS=2048,NDARRAY_PORT=PCO1") NDTimeSeriesConfigure("STATS3_TS", 20, 0, "STATS3", 1, 23) dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDTimeSeries.template", "P=PCO1600:,R=Stats3:TS:, PORT =STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS4", 20, 0, "ROI3", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=PCO1600:,R=Stats4:, PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2560,YSIZ E=2160,NCHANS=2048,NDARRAY_PORT=PCO1") NDTimeSeriesConfigure("STATS4_TS", 20, 0, "STATS4", 1, 23) dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDTimeSeries.template", "P=PCO1600:,R=Stats4:TS:, PORT =STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS5", 20, 0, "ROI4", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=PCO1600:,R=Stats5:, PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2560,YSIZ E=2160,NCHANS=2048,NDARRAY_PORT=PCO1") NDTimeSeriesConfigure("STATS5_TS", 20, 0, "STATS5", 1, 23) dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDTimeSeries.template", "P=PCO1600:,R=Stats5:TS:, PORT =STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") # Create a transform plugin NDTransformConfigure("TRANS1", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDTransform.template", "P=PCO1600:,R=Trans1:, PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create an overlay plugin with 8 overlays NDOverlayConfigure("OVER1", 20, 0, "PCO1", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDOverlay.template", "P=PCO1600:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:1:,NAME=ROI1, SHAPE=1,O=Over1:,XPOS=PCO1600:ROI1:MinX_RBV,YPOS =PCO1600:ROI1:MinY_RBV,XSIZE=PCO1600:ROI1:SizeX_RBV,YSIZE=PCO1600:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:2:,NAME=ROI2, SHAPE=1,O=Over1:,XPOS=PCO1600:ROI2:MinX_RBV,YPOS =PCO1600:ROI2:MinY_RBV,XSIZE=PCO1600:ROI2:SizeX_RBV,YSIZE=PCO1600:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:3:,NAME=ROI3, SHAPE=1,O=Over1:,XPOS=PCO1600:ROI3:MinX_RBV,YPOS =PCO1600:ROI3:MinY_RBV,XSIZE=PCO1600:ROI3:SizeX_RBV,YSIZE=PCO1600:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:4:,NAME=ROI4, SHAPE=1,O=Over1:,XPOS=PCO1600:ROI4:MinX_RBV,YPOS =PCO1600:ROI4:MinY_RBV,XSIZE=PCO1600:ROI4:SizeX_RBV,YSIZE=PCO1600:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk, YPO S=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=4,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk, YPO S=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=5,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:7:,NAME=Box1, SHAPE=1,O=Over1:,XPOS=junk, YPO S=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=6,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=PCO1600:,R=Over1:8:,NAME=Box2, SHAPE=1,O=Over1:,XPOS=junk, YPO S=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=7,TIMEOUT=1") # Create 2 color conversion plugins NDColorConvertConfigure("CC1", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=PCO1600:,R=CC1:, PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") NDColorConvertConfigure("CC2", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=PCO1600:,R=CC2:, PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create a circular buffer plugin NDCircularBuffConfigure("CB1", 20, 0, "PCO1", 0, 500, 0) dbLoadRecords("NDCircularBuff.template", "P=PCO1600:,R=CB1:, PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PCO1") # Create an NDAttribute plugin with 8 attributes NDAttrConfigure("ATTR1", 20, 0, "PCO1", 0, 8, 0, 0, 0) dbLoadRecords("NDAttribute.template", "P=PCO1600:,R=Attr1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=PCO 1") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:2:, PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:3:, PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:4:, PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:5:, PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:6:, PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:7:, PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=PCO1600:,R=Attr1:8:, PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048") NDTimeSeriesConfigure("ATTR1_TS", 20, 0, "ATTR1", 1, 8) dbLoadRecords("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/db/NDTimeSeries.template", "P=PCO1600:,R=Attr1:TS:, PORT= ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") # Create an FFT plugin NDFFTConfigure("FFT1", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDFFT.template", "P=PCO1600:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=PCO1, NAME=FFT1, NCHANS =2560") # Create 2 Codec plugins NDCodecConfigure("CODEC1", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDCodec.template", "P=PCO1600:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=PCO1") NDCodecConfigure("CODEC2", 20, 0, "PCO1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDCodec.template", "P=PCO1600:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=PCO1") set_requestfile_path("./") set_requestfile_path("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/ADApp/Db") set_requestfile_path("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADCore/iocBoot") set_savefile_path("./autosave") set_pass0_restoreFile("auto_settings.sav") set_pass1_restoreFile("auto_settings.sav") save_restoreSet_status_prefix("PCO1600:") dbLoadRecords("C:/epics/inst-7.0.3.1/autosave-R5-10/asApp/Db/save_restoreStatus.db", "P=PCO1600:") # Optional: load NDPluginPva plugin #NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0) #dbLoadRecords("NDPva.template", "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Must start PVA server if this is enabled #startPVAServer # Optional: load ffmpegServer plugin #ffmpegServerConfigure(8081) #ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0) #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(POR T)") #ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0) #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)") # Optional: load NDPluginEdge plugin #NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0) #dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template", "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$( PORT)") #set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db") # Optional: load NDPluginCV plugin #NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5)) #dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template", "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)" ) #set_requestfile_path("$(ADCOMPVISION)/adcvApp/Db") # Optional: load NDPluginBar plugin #NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5)) #dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template", "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT )") #set_requestfile_path("$(ADPLUGINBAR)/barApp/Db") # Optional: load scan records dbLoadRecords("C:/epics/inst-7.0.3.1/sscan-R2-11-3/sscanApp/Db/scan.db", "P=PCO1600:,MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20 ,MAXPTS4=10,MAXPTSH=10") set_requestfile_path("C:/epics/inst-7.0.3.1/sscan-R2-11-3/sscanApp/Db") # Optional: load sseq record for acquisition sequence dbLoadRecords("C:/epics/inst-7.0.3.1/calc-R3-7-3/calcApp/Db/sseqRecord.db", "P=PCO1600:, S=AcquireSequence") set_requestfile_path("C:/epics/inst-7.0.3.1/calc-R3-7-3/calcApp/Db") # Optional: load devIocStats records (requires DEVIOCSTATS module) #dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)") # Optional: load alive record (requires ALIVE module) #dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254") # Set the callback queue size to 5000, up from default of 2000 in base. # This can be needed to avoid errors "callbackRequest: cbLow ring buffer full". callbackSetQueueSize(5000) set_requestfile_path("C:/epics/inst-7.0.3.1/areaDetector-R3-9/ADPcoWin/iocs/pcowinIOC/../../pcowinApp/Db") iocInit() Starting iocInit ############################################################################ ## EPICS R7.0.3.1 ## EPICS Base built Feb 28 2020 ############################################################################ reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) *** reboot_restore: done with file 'auto_settings.sav' reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) *** reboot_restore: done with file 'auto_settings.sav' iocRun: All initialization complete # save things every thirty seconds create_monitor_set("auto_settings.req", 30,"P=PCO1600:") epics> auto_settings.sav: 2277 of 2277 PV's connected pco.1600 : Found 14 devices on camera Warning: Not enough parameters available to store camera device information (limit of 8 devices) epics> As mentioned by Oksana on the 26.02 I added the ...\areaDetector\ADPcoWin\iocs\pcowinIOC\bin\windows-x64-static .dll to Path. The last warning comes ~20s after "epics> auto_settings.sav: 2277 of 2277 PV's connected". Is it just a warning or something to worry about? ________________________________ Von: Ivashkevych, Oksana <[email protected]> Gesendet: Samstag, 29. Februar 2020 01:31:07 An: Mark Rivers; Sintschuk, Michael Cc: [email protected] Betreff: Re: pco Camera USB and IEEE interface There are .opi screens translated from edl ones developed by Diamond. https://github.com/areaDetector/ADPcoWin/tree/master/pcowinApp/opi/opi Control System Studio will work with those. There is no need to build it, you can download and unzip. https://controlssoftware.sns.ornl.gov/css_rcp/ .edl and converted .opi screens are a collection of different perspectives on pco camera features rather then a one specific screen as for other detectors. Both set of screens are functionally identical. Oksana ________________________________ From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]> Sent: Friday, February 28, 2020 18:30 To: 'Sintschuk, Michael' Cc: [email protected] Subject: RE: pco Camera USB and IEEE interface I have fixed the problems with dynamic builds of ADPcoWin. There is a fix_dynamic branch on Github and a pull request pending for master. Ø Somehow I struggle with the EPICS-extensions package stuff (https://github.com/epics-extensions/extensions) and edm ... If you send the errors we can probably help figure them out. Ø Maybe there is a more simple way to open the GUI files for the camera? Currently there are only edm screens. Most detectors have medm screens, and then those are autoconverted to edm, caQtDM, CSS/BOY, and CSS/Phoebus. But no one ever created medm screens for ADPcoWin. Mark From: Sintschuk, Michael <[email protected]> Sent: Friday, February 28, 2020 10:22 AM To: Mark Rivers <[email protected]> Cc: [email protected] Subject: AW: pco Camera USB and IEEE interface Hi Mark, thanks for the update! Today I tried the static build as you told but ADPcoWin crashed because of qsrv was not found. For qsrv I have to compile epics-pva when I use EPICS-base lower then 7. This was when I decided to switch to the lates EPICS-base-7.0.3.1. So I compiled everything static with base-7.0.3.1 and MVS 2019 community and it worked! I also could set-up an IOC that connected a pco.1600. At least I think so... Now I'm compiling the edm software (https://github.com/gnartohl/edm) on a linux-x86_64 against EPICS-base-3.15.7 in order to open the GUI files located in: ADPcoWin/pcowinApp/opi/edl/ Maybe there is a more simple way to open the GUI files for the camera? Somehow I struggle with the EPICS-extensions package stuff (https://github.com/epics-extensions/extensions) and edm ... For the overview: the IOC is supposed to run on the Windows-7 computer where the pco.1600 is connected (USB) and where I compiled all the EPICS-base-7.0.3.1 environment that is needed for the IOC. But the control GUI shall run on a linux-x86_64 computer where I have an EPICS-base-3.15.7 environment. Again: thanks for the help! Michael ________________________________ Von: Mark Rivers <[email protected]<mailto:[email protected]>> Gesendet: Freitag, 28. Februar 2020 15:30:09 An: Sintschuk, Michael Cc: [email protected]<mailto:[email protected]> Betreff: RE: pco Camera USB and IEEE interface Hi Michael, I just tried building ADPcoWin with the windows-x64 architecture and Visual Studio 2015. I get the same error you do. I was able to fix that error, but then ran into a more fundamental problem. When building dynamically the vendor libraries need to be linked with using LIB_LIBS. The pcowinApp/src/Makefile installs those vendor libraries using LIB_INSTALLS and BIN_INSTALLS. However, the LIB_INSTALLS and BIN_INSTALLS operations happen after the library is built, not before, so it is too late and the link operation fails. The Makefile also was not linking the library with ADCore, asyn, vendor libraries, etc. Clearly dynamic builds of ADPcoWin had never been tested. I am working on a fix, but meanwhile if you build with EPICS_HOST_ARCH=windows-x64-static it should work. It just worked OK for me with Visual Studio 2015. Mark From: Mark Rivers <[email protected]<mailto:[email protected]>> Sent: Wednesday, February 26, 2020 10:20 AM To: Sintschuk, Michael <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> Subject: Re: pco Camera USB and IEEE interface I have built this on the windows-x64-static architecture with VS2015. Can you try building windows-x64-static rather than windows-x64 (dynamic)? Mark ________________________________ From: Sintschuk, Michael <[email protected]<mailto:[email protected]>> Sent: Wednesday, February 26, 2020 9:44 AM To: Mark Rivers Cc: [email protected]<mailto:[email protected]> Subject: AW: pco Camera USB and IEEE interface Hi Mark, ok, now I took the latest master-branch release and got a little further: make -C C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin install make[1]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin' make -C ./configure install make[2]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure' perl -CSD C:/epics/base-3.15.7/bin/windows-x64/makeMakefile.pl O.windows-x64 ../.. perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. \ T_A=windows-x64 install make[3]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64' perl -CSD C:/epics/base-3.15.7/bin/windows-x64/convertRelease.pl checkRelease make[3]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64' make[2]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure' make -C ./pcowinApp install make[2]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp' make -C ./src install make[3]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src' perl -CSD C:/epics/base-3.15.7/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. \ T_A=windows-x64 install make[4]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src/O.windows-x64' perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m PcoApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/e pics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15. 7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ PcoApi.obj ../PcoA pi.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m NdArrayRef.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I C:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3 .15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ NdArrayRef.obj ../NdArrayRef.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m ADDriverEx.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I C:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3 .15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ ADDriverEx.obj ../ADDriverEx.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m PcoCameraDevice.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/i nst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ PcoCamera Device.obj ../PcoCameraDevice.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m AsynParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC :/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3. 15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ AsynParam.obj . ./AsynParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m StringParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include - IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst- 3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ StringParam.o bj ../StringParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m DoubleParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include - IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst- 3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ DoubleParam.o bj ../DoubleParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m IntegerParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst -3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ IntegerParam .obj ../IntegerParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m FreeLock.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC: /epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.1 5.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ FreeLock.obj ../ FreeLock.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m TakeLock.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC: /epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.1 5.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ TakeLock.obj ../ TakeLock.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m SimulationApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/ins t-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ SimulationA pi.obj ../SimulationApi.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m PcoException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst -3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ PcoException .obj ../PcoException.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m PerformanceMonitor.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epic s/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Perfor manceMonitor.obj ../PerformanceMonitor.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m SocketProtocol.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/in st-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ SocketProt ocol.obj ../SocketProtocol.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangServerConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/ inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangServ erConfig.obj ../GangServerConfig.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangMemberConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/ inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangMemb erConfig.obj ../GangMemberConfig.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I C:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3 .15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangConfig.obj ../GangConfig.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangConnection.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/in st-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangConnec tion.obj ../GangConnection.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangClient.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I C:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3 .15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangClient.obj ../GangClient.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangServer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I C:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3 .15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangServer.obj ../GangServer.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m TraceStream.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include - IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst- 3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ TraceStream.o bj ../TraceStream.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m StateMachine.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst -3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ StateMachine .obj ../StateMachine.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m AsynException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/ins t-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ AsynExcepti on.obj ../AsynException.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m NDArrayException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/ inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ NDArrayE xception.obj ../NDArrayException.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m DllApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/e pics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15. 7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ DllApi.obj ../DllA pi.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m Pco.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epic s/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/a reaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Pco.obj ../Pco.cpp "Installing dbd file ../../../dbd/pcowinSupport.dbd" mkdir ../../../dbd "Installing dbd file ../../../dbd/pcowinHardwareSupport.dbd" cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../Pco.cpp Pco.cpp C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\Pco.cpp(1701): warning C4838: Konvertierung von "int" zu "size_t" erfordert eine einschränkende Konvertierung C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\Pco.cpp(1701): warning C4838: Konvertierung von "int" zu "size_t" erfordert eine einschränkende Konvertierung C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\Pco.cpp(2531): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\Pco.cpp(2532): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../DllApi.cpp DllApi.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../NDArrayException.cpp NDArrayException.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../AsynException.cpp AsynException.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../StateMachine.cpp StateMachine.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../TraceStream.cpp TraceStream.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../GangServer.cpp GangServer.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../GangClient.cpp GangClient.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../GangConnection.cpp GangConnection.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../GangConfig.cpp GangConfig.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../GangMemberConfig.cpp GangMemberConfig.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../GangServerConfig.cpp GangServerConfig.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../SocketProtocol.cpp SocketProtocol.cpp C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcowinApp\src\SocketProtocol.cpp(193): warning C4996: 'gethostbyname': Use getaddrinfo() or GetAddrInfoW() instead or define _WINSOCK_DEPRECAT ED_NO_WARNINGS to disable deprecated API warnings C:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\um\winsock2.h(2219): note: Siehe Deklaration von "gethostbyname" cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../PerformanceMonitor.cpp PerformanceMonitor.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../PcoException.cpp PcoException.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../SimulationApi.cpp SimulationApi.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../TakeLock.cpp TakeLock.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../FreeLock.cpp FreeLock.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../IntegerParam.cpp IntegerParam.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../DoubleParam.cpp DoubleParam.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../StringParam.cpp StringParam.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../AsynParam.cpp AsynParam.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../PcoCameraDevice.cpp PcoCameraDevice.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../ADDriverEx.cpp ADDriverEx.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../NdArrayRef.cpp NdArrayRef.cpp cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include/os/WIN32 -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADSupport/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/ep ics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../PcoApi.cpp PcoApi.cpp C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\ATLMFC\include\afx.h(24): fatal error C1189: #error: Building MFC application with /MD[d] (CRT dll ve rsion) requires MFC shared dll version. Please #define _AFXDLL or do not use /MD[d] make[4]: *** [C:/epics/base-3.15.7/configure/RULES_BUILD:240: PcoApi.obj] Error 2 make[4]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src/O.windows-x64' make[3]: *** [C:/epics/base-3.15.7/configure/RULES_ARCHS:58: install.windows-x64] Error 2 make[3]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp/src' make[2]: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: src.install] Error 2 make[2]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcowinApp' make[1]: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: pcowinApp.install] Error 2 make[1]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin' make: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin.install] Error 2 Still there is an error. Has someone ever compiled this package with the setup I have: windows 7 64bit, Microsoft Visual Studio\2019\Community ? Michael ________________________________ Von: Mark Rivers <[email protected]<mailto:[email protected]>> Gesendet: Mittwoch, 26. Februar 2020 13:53:11 An: Sintschuk, Michael Cc: [email protected]<mailto:[email protected]> Betreff: Re: pco Camera USB and IEEE interface Hi Michael, I believe all of the errors that you are getting are because you are not using the master branch of ADPcoWin. In particular you are missing this commit: **************************** commit 950dbdd9471184e4f6c428051ae982544272e8cd Author: Mark Rivers <[email protected]<mailto:[email protected]>> Date: Mon Mar 25 08:23:18 2019 -0500 Add <algorithm> include; change NDArrayPool buffer functions for new versions **************************** Including <algorithm> should eliminate these errors: C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2545): error C2039: "min": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2545): error C3861: "min": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2546): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2546): error C3861: "max": Bezeichner wurde nicht gefunden. The changes to NDArrayPool in that commit should eliminate these errors: C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1525): error C2039: "numBuffers": Ist kein Element von "NDArrayPool" C:\epics\inst-3.15.7\areaDetector-R3-8\ADCore\include\NDArray.h(161): note: Siehe Deklaration von "NDArrayPool" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1525): error C2039: "numFree": Ist kein Element von "NDArrayPool" C:\epics\inst-3.15.7\areaDetector-R3-8\ADCore\include\NDArray.h(161): note: Siehe Deklaration von "NDArrayPool" Note that there are lots of other commits since March 25, 2019 as well. However, the last release was 4.0 on February 27, 2019. It looks like there should probably be a new release of this module. The folks from Diamond (Ben Bradnick, Ulrik Pederson, and others) are in charge of this module. Meanwhile try using the master branch. Mark ________________________________ From: Sintschuk, Michael <[email protected]<mailto:[email protected]>> Sent: Wednesday, February 26, 2020 5:30 AM To: Mark Rivers Cc: [email protected]<mailto:[email protected]> Subject: AW: pco Camera USB and IEEE interface Hi Mark, I followed your advice and recompiled my EPICS-base 3.15.7 and the required modules asyn, calc ... etc. that are needed for areaDetector with Microsoft Visual Studio-2019 Community-Edition (x64) succesfully. However when I make areaDetector with all the standard-settings described in the Installation-Guide, it runs about 5min until it gets to the ADPcoWin-module and crashes with the following errors: make[1]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADCore' make -C C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin install make[1]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin' make -C ./configure install make[2]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure' perl -CSD C:/epics/base-3.15.7/bin/windows-x64/makeMakefile.pl O.windows-x64 ../.. perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. \ T_A=windows-x64 install make[3]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64' make[3]: Nothing to be done for 'install'. make[3]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64' make[2]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/configure' make -C ./pcocam2App install make[2]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App' make -C ./src install make[3]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src' perl -CSD C:/epics/base-3.15.7/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. \ T_A=windows-x64 install make[4]: Entering directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64' perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m PcoApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC :/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epics/i nst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ PcoApi .obj ../PcoApi.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m NdArrayRef.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epi cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Nd ArrayRef.obj ../NdArrayRef.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m ADDriverEx.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epi cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ AD DriverEx.obj ../ADDriverEx.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m AsynParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epic s/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Asy nParam.obj ../AsynParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m StringParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/ep ics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ S tringParam.obj ../StringParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m DoubleParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/ep ics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ D oubleParam.obj ../DoubleParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m IntegerParam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/e pics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ IntegerParam.obj ../IntegerParam.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m FreeLock.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include - IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epics /inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Free Lock.obj ../FreeLock.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m TakeLock.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include - IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epics /inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Take Lock.obj ../TakeLock.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m SimulationApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/ epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ SimulationApi.obj ../SimulationApi.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m PcoException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/e pics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ PcoException.obj ../PcoException.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m PerformanceMonitor.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../includ e/ PerformanceMonitor.obj ../PerformanceMonitor.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m SocketProtocol.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC: /epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ SocketProtocol.obj ../SocketProtocol.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangServerConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangServerConfig.obj ../GangServerConfig.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangMemberConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangMemberConfig.obj ../GangMemberConfig.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangConfig.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epi cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Ga ngConfig.obj ../GangConfig.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangConnection.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC: /epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ GangConnection.obj ../GangConnection.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangClient.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epi cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Ga ngClient.obj ../GangClient.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m GangServer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epi cs/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Ga ngServer.obj ../GangServer.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m TraceStream.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/ep ics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ T raceStream.obj ../TraceStream.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m StateMachine.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/e pics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ StateMachine.obj ../StateMachine.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m AsynException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/ epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ AsynException.obj ../AsynException.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m NDArrayException.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -I C:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ NDArrayException.obj ../NDArrayException.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m DllApi.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC :/epics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epics/i nst-3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ DllApi .obj ../DllApi.cpp perl -CSD C:/epics/base-3.15.7/bin/windows-x64/mkmf.pl -m Pco.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/e pics/inst-3.15.7/asyn-R4-37/include -IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epics/inst -3.15.7/areaDetector-R3-8/ADCore/include -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ Pco.obj . ./Pco.cpp "Installing dbd file ../../../dbd/pcocam2Support.dbd" mkdir ../../../dbd "Installing dbd file ../../../dbd/pcocam2HardwareSupport.dbd" cl -EHsc -GR /O2 /wd4290 -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_ DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/epics/inst-3.15.7/asyn-R4-37/include - IC:/epics/inst-3.15.7/calc-R3-7-3/include -IC:/epics/inst-3.15.7/sscan-R2-11-3/include -IC:/epics/inst-3.15.7/busy-R1-7-2/include -IC:/epics/inst-3.15.7/areaDetector-R3-8/ADCore/includ e -IC:/epics/base-3.15.7/include/compiler/msvc -IC:/epics/base-3.15.7/include/os/WIN32 -IC:/epics/base-3.15.7/include -I../include/ -c ../Pco.cpp Pco.cpp C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1525): error C2039: "numBuffers": Ist kein Element von "NDArrayPool" C:\epics\inst-3.15.7\areaDetector-R3-8\ADCore\include\NDArray.h(161): note: Siehe Deklaration von "NDArrayPool" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1525): error C2039: "numFree": Ist kein Element von "NDArrayPool" C:\epics\inst-3.15.7\areaDetector-R3-8\ADCore\include\NDArray.h(161): note: Siehe Deklaration von "NDArrayPool" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1701): warning C4838: Konvertierung von "int" zu "size_t" erfordert eine einschränkende Konvertierung C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(1701): warning C4838: Konvertierung von "int" zu "size_t" erfordert eine einschränkende Konvertierung C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2527): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2527): error C3861: "max": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2528): error C2039: "min": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2528): error C3861: "min": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2529): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2529): error C3861: "max": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2530): error C2039: "min": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2530): error C3861: "min": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2533): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2534): warning C4244: "=": Konvertierung von "double" in "int", möglicher Datenverlust C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2542): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2542): error C3861: "max": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2543): error C2039: "min": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2543): error C3861: "min": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2544): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2544): error C3861: "max": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2545): error C2039: "min": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2545): error C3861: "min": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2546): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2546): error C3861: "max": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2547): error C2039: "min": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2547): error C3861: "min": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2548): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2548): error C3861: "max": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2549): error C2039: "min": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2549): error C3861: "min": Bezeichner wurde nicht gefunden. C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2723): error C2039: "max": Ist kein Element von "std" C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.24.28314\include\cstdarg(21): note: Siehe Deklaration von "std" C:\epics\inst-3.15.7\areaDetector-R3-8\ADPcoWin\pcocam2App\src\Pco.cpp(2723): error C3861: "max": Bezeichner wurde nicht gefunden. make[4]: *** [C:/epics/base-3.15.7/configure/RULES_BUILD:240: Pco.obj] Error 2 make[4]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64' make[3]: *** [C:/epics/base-3.15.7/configure/RULES_ARCHS:58: install.windows-x64] Error 2 make[3]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App/src' make[2]: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: src.install] Error 2 make[2]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin/pcocam2App' make[1]: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: pcocam2App.install] Error 2 make[1]: Leaving directory 'C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin' make: *** [C:/epics/base-3.15.7/configure/RULES_DIRS:84: C:/epics/inst-3.15.7/areaDetector-R3-8/ADPcoWin.install] Error 2 The errors are in german but I think quite understandable... I already tried it with adding some extra MSVC-packages for my visual studio: one can adjust the Microsoft Visual Studio - Edition with the Visual Studio Installer. So my folder C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC contains not only 14.24.28314 but also 14.23.28105 ; 14.22.27905 ; 14.21.27702 ; 14.20.27508. But with no success. Before I start to make, I run the windows.bat file, located in C:\epics\base-3.15.7\startup , which I edited the following way: @echo off rem ************************************************************************* rem Copyright (c) 2017 UChicago Argonne LLC, as Operator of Argonne rem National Laboratory. rem Copyright (c) 2002 The Regents of the University of California, as rem Operator of Los Alamos National Laboratory. rem EPICS BASE is distributed subject to a Software License Agreement found rem in file LICENSE that is included with this distribution. rem ************************************************************************* rem rem Site-specific EPICS environment settings rem rem Sets EPICS_HOST_ARCH and the environment for Microsoft Visual Studio. rem Optionally, resets PATH, adds Strawberry Perl to PATH, and adds the rem EPICS Base install host architecture bin directory to PATH. rem rem ---------------------------------------------------------------------- rem Site serviceable parts (These definitions may be modified) rem ---------------------------------------------------------------------- rem The values of the definitions in this section must not contain rem double-quotes. rem rem * Right: set _foo=C:\foo rem * Right: set "_foo=C:\foo" rem * Wrong: set _foo="C:\foo" rem Automatically set up the environment when possible ("yes" or "no"). rem If set to yes, as much of the environment will be set up as possible. rem If set to no, just the minimum environment will be set up. More rem specific _auto_* definitions take precedence over this definition. set _auto=no rem Automatically reset PATH ("yes" or "no"). If set to yes, PATH will rem be reset to the value of _path_new. If set to no, PATH will not be rem reset. set _auto_path_reset=%_auto% rem Automatically append to PATH ("yes" or "no"). If set to yes, the rem EPICS Base install host architecture bin directory will be added to rem PATH if possible. If set to no, the bin directory will not be added rem to PATH. set _auto_path_append=%_auto% rem The new value for PATH. If _auto_path_reset is yes, PATH will be set rem to it. set _path_new=C:\Windows\System32;C:\Windows;C:\Windows\System32\wbem rem The location of Strawberry Perl (pathname). If empty, Strawberry Perl rem is assumed to already be in PATH and will not be added. If nonempty, rem Strawberry Perl will be added to PATH. set _strawberry_perl_home=C:\Strawberry rem The location of Microsoft Visual Studio (pathname). set _visual_studio_home=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community rem The EPICS host architecture specification for EPICS_HOST_ARCH rem (<os>-<arch>[-<toolset>] as defined in configure/CONFIG_SITE). set _epics_host_arch=windows-x64 rem The install location of EPICS Base (pathname). If nonempty and rem _auto_path_append is yes, it will be used to add the host architecture rem bin directory to PATH. set _epics_base=C:\epics\base-3.15.7 rem ---------------------------------------------------------------------- rem Internal parts (There is typically no need to modify these) rem ---------------------------------------------------------------------- rem Reset PATH if "%_auto_path_reset%" == "yes" ( set "PATH=%_path_new%" ) rem Add Strawberry Perl to PATH if "%_strawberry_perl_home%" == "" goto after_add_strawberry_perl rem Can't do this inside parentheses because PATH would be read only once set "PATH=%PATH%;%_strawberry_perl_home%\c\bin" set "PATH=%PATH%;%_strawberry_perl_home%\perl\site\bin" set "PATH=%PATH%;%_strawberry_perl_home%\perl\bin" :after_add_strawberry_perl rem Set the environment for Microsoft Visual Studio call "%_visual_studio_home%\VC\Auxiliary\Build\vcvarsall.bat" x64 rem Set the EPICS host architecture specification set "EPICS_HOST_ARCH=%_epics_host_arch%" rem Add the EPICS Base host architecture bin directory to PATH if "%_auto_path_append%" == "yes" ( if not "%_epics_base%" == "" ( set "PATH=%PATH%;%_epics_base%\bin\%_epics_host_arch%" ) ) rem Don't leak variables into the environment set _auto= set _auto_path_reset= set _auto_path_append= set _path_new= set _strawberry_perl_home= set _visual_studio_home= set _epics_host_arch= set _epics_base= It worked with all the other compilations so far... Thanks in advance. Michael ________________________________ Von: Mark Rivers <[email protected]> Gesendet: Dienstag, 28. Januar 2020 19:19:26 An: Sintschuk, Michael Cc: [email protected] Betreff: RE: pco Camera USB and IEEE interface Hi Michael, Ø I'm trying to install the areaDetector module with the help of this guide: Ø https://areadetector.github.io/master/install_guide.html<https://urldefense.com/v3/__https://areadetector.github.io/master/install_guide.html__;!!P4SdNyxKAPE!U-CcINddgQUCmULr_RnZwLu6EZ0w50VHKqDvNdB6SM_pTqCWquXcK6pL7VjA6g$> Ø and with the ADPcoWin package. At some point I get the following errors: It looks like you are compiling ADPcoWin with mingw and not Visual Studio. I doubt if anyone has tried that, and it may well not work. In addition, your configuration of mingw is setting the /O2 /wd4290 flags, but mingw is misinterpreting those as directories, not flags. I don't see those flags in EPICS base/configure/os, so they must be coming from somewhere else? If you can figure out how to get rid of the /O2 and /wd4290 flags you may be able to build it with mingw. If not, I suggest installing Visual Studio Community Edition (free) and compiling with that. Mark From: Sintschuk, Michael <[email protected]> Sent: Tuesday, January 28, 2020 10:42 AM To: Mark Rivers <[email protected]> Cc: [email protected] Subject: AW: pco Camera USB and IEEE interface Hello again, I'm trying to install the areaDetector module with the help of this guide: https://areadetector.github.io/master/install_guide.html<https://urldefense.com/v3/__https://areadetector.github.io/master/install_guide.html__;!!P4SdNyxKAPE!U-CcINddgQUCmULr_RnZwLu6EZ0w50VHKqDvNdB6SM_pTqCWquXcK6pL7VjA6g$> and with the ADPcoWin package. At some point I get the following errors: . . . . . make[1]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADCore' C:/Strawberry/c/bin/make -C /epics/modules/areaDetector-R3-8/ADPcoWin install make[1]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin' C:/Strawberry/c/bin/make -C ./configure install make[2]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure' perl -CSD C:/epics/base-3.15.7/bin/windows-x64-mingw/makeMakefile.pl O.windows-x64-mingw ../.. perl -CSD -MExtUtils::Command -e mkpath O.Common C:/Strawberry/c/bin/make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \ T_A=windows-x64-mingw install make[3]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64-mingw' make[3]: Nothing to be done for 'install'. make[3]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure/O.windows-x64-mingw' make[2]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/configure' C:/Strawberry/c/bin/make -C ./pcocam2App install make[2]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App' C:/Strawberry/c/bin/make -C ./src install make[3]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src' perl -CSD C:/epics/base-3.15.7/bin/windows-x64-mingw/makeMakefile.pl O.windows-x64-mingw ../../.. perl -CSD -MExtUtils::Command -e mkpath O.Common C:/Strawberry/c/bin/make -C O.windows-x64-mingw -f ../Makefile TOP=../../.. \ T_A=windows-x64-mingw install make[4]: Entering directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64-mingw' g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF PcoApi.d -MT PcoApi.obj ../PcoApi.cp p g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF NdArrayRef.d -MT NdArrayRef.obj ../N dArrayRef.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF ADDriverEx.d -MT ADDriverEx.obj ../A DDriverEx.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF AsynParam.d -MT AsynParam.obj ../Asy nParam.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF StringParam.d -MT StringParam.obj .. /StringParam.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF DoubleParam.d -MT DoubleParam.obj .. /DoubleParam.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF IntegerParam.d -MT IntegerParam.obj ../IntegerParam.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF FreeLock.d -MT FreeLock.obj ../FreeL ock.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF TakeLock.d -MT TakeLock.obj ../TakeL ock.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF SimulationApi.d -MT SimulationApi.ob j ../SimulationApi.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF PcoException.d -MT PcoException.obj ../PcoException.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF PerformanceMonitor.d -MT Performance Monitor.obj ../PerformanceMonitor.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF SocketProtocol.d -MT SocketProtocol. obj ../SocketProtocol.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF GangServerConfig.d -MT GangServerCon fig.obj ../GangServerConfig.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF GangMemberConfig.d -MT GangMemberCon fig.obj ../GangMemberConfig.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF GangConfig.d -MT GangConfig.obj ../G angConfig.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF GangConnection.d -MT GangConnection. obj ../GangConnection.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF GangClient.d -MT GangClient.obj ../G angClient.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF GangServer.d -MT GangServer.obj ../G angServer.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF TraceStream.d -MT TraceStream.obj .. /TraceStream.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF StateMachine.d -MT StateMachine.obj ../StateMachine.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF AsynException.d -MT AsynException.ob j ../AsynException.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF NDArrayException.d -MT NDArrayExcept ion.obj ../NDArrayException.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF DllApi.d -MT DllApi.obj ../DllApi.cp p g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -MM -MF Pco.d -MT Pco.obj ../Pco.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory "Installing dbd file ../../../dbd/pcocam2Support.dbd" mkdir ../../../dbd "Installing dbd file ../../../dbd/pcocam2HardwareSupport.dbd" g++ /O2 /wd4290 -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -I/epics/modules/asyn- R4-37/include -I/epics/modules/calc-R3-7-3/include -I/epics/modules/sscan-R2-11-3/include -I/epics/modules/busy-R1 -7-2/include -I/epics/modules/areaDetector-R3-8/ADCore/include -I/epics/base-3.15.7/include/compiler/gcc -I/epics/base -3.15.7/include/os/WIN32 -I/epics/base-3.15.7/include -I../include/ -o Pco.obj -c ../Pco.cpp g++: error: /O2: No such file or directory g++: error: /wd4290: No such file or directory make[4]: *** [/epics/base-3.15.7/configure/RULES_BUILD:240: Pco.obj] Error 1 make[4]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src/O.windows-x64-mingw' make[3]: *** [/epics/base-3.15.7/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2 make[3]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App/src' make[2]: *** [/epics/base-3.15.7/configure/RULES_DIRS:84: src.install] Error 2 make[2]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin/pcocam2App' make[1]: *** [/epics/base-3.15.7/configure/RULES_DIRS:84: pcocam2App.install] Error 2 make[1]: Leaving directory 'C:/epics/modules/areaDetector-R3-8/ADPcoWin' make: *** [/epics/base-3.15.7/configure/RULES_DIRS:84: /epics/modules/areaDetector-R3-8/ADPcoWin.install] Error 2 PS C:\epics\modules\areaDetector-R3-8> It seems there are no "/O2" "/wd4290" directories... Did I missed something in the config files? My CONFIG_SITE.local (located in: C:\epics\modules\areaDetector-R3-8\configure) looks like this: # To build the IOC applications set BUILD_IOCS to YES # Otherwise set it to NO BUILD_IOCS=YES # To build areaDetector so that it only depends on libCom and asyn set the following flag #EPICS_LIBCOM_ONLY=YES # Configure which 3rd party libraries to use and where to find them. # For each library XXX the following definitions are used: # WITH_XXX Build the plugins and drivers that require this library. # Build the source code for this library in ADSupport if XXX_EXTERNAL=NO. # XXX_EXTERNAL If NO then build the source code for this library in ADSupport. # XXX_INCLUDE If XXX_EXTERNAL=YES then this is the path to the include files for XXX. # However, if XXX is a system library whose include files are in a # standard include search path then do not define XXX_INCLUDE. # XXX_LIB If XXX_EXTERNAL=YES then this is the path to the library files for XXX. # However, if XXX is a system library whose library files in a # standard library search path then do not define XXX_LIB. # The exception to the above is XML2. # As of ADCORE R3-0 libxml2 is required for ADCore so WITH_XML2 is not supported # but the other XML2 flags are supported. # The default defined here is appropriate for most Linux systems. # BOOST is required for the ADCore/pluginTests unit tests WITH_BOOST = NO BOOST_EXTERNAL = YES #BOOST_LIB = #BOOST_INCLUDE = # Uncomment this line if you want to use STATIC Linking when building # ADCore/pluginTests unit tests. #BOOST_USE_STATIC_LINK=YES # EPICS PVA is required for NDPluginPva, pvaDriver, and qsrv WITH_PVA = NO # WITH_QSRV controls whether IOCs are built with support for qsrv. # This is separate from WITH_PVA to allow PVA to be enabled but QSRV to be disabled. # This is needed on 3.14.12 where PVA is supported but QSRV is not. # Note that if WITH_QSRV=YES then WITH_PVA must also be YES WITH_QSRV = NO # BLOSC is required to use the blosc compressors in the HDF5 plugin WITH_BLOSC = NO BLOSC_EXTERNAL = NO #BLOSC_INCLUDE = #BLOSC_LIB = # BITSHUFFLE is required to use the bitshuffle/LZ4 decompressors in the ADEiger driver # It can also be used to generate shareable libraries for the HDF5 compressor/decompressor WITH_BITSHUFFLE = NO BITSHUFFLE_EXTERNAL = NO # GraphicsMagick is required for NDFileMagick and the URL driver. WITH_GRAPHICSMAGICK = NO GRAPHICSMAGICK_EXTERNAL = NO # GraphicsMagick defines many global symbols, and one of these (SetImage) conflicts with a symbol # in the Andor vendor library. GraphickMagick provides a solution by allowing all external library # symbols to be prefixed with "Gm". Enable using this by default. However, if a system library # is used it may not be built with this option so this line should be commented out. GRAPHICSMAGICK_PREFIX_SYMBOLS = NO #GRAPHICSMAGICK_INCLUDE = #GRAPHICSMAGICK_LIB = # HDF5 is required for the NDFileHDF5 and NDFileNexus plugins WITH_HDF5 = NO HDF5_EXTERNAL = NO #HDF5_INCLUDE = #HDF5_LIB = # JPEG is required for the NDFileJPEG and NDFileTIFF plugins WITH_JPEG = YES JPEG_EXTERNAL = NO #JPEG_INCLUDE = #JPEG_LIB = # JPEG is required for the NDFileNetCDF plugin WITH_NETCDF = NO NETCDF_EXTERNAL = NO #NETCDF_INCLUDE = #NETCDF_LIB = # NEXUS is required for the NDFileNexus plugin WITH_NEXUS = NO NEXUS_EXTERNAL = NO #NEXUS_INCLUDE = #NEXUS_LIB = # OPENCV is required for the ADPluginEdge plugin WITH_OPENCV = NO OPENCV_EXTERNAL = YES #OPENCV_INCLUDE = #OPENCV_LIB = # SZIP is required for the NDFileHDF5 and NDFileNexus plugins. # This may be optional in the future. WITH_SZIP = NO SZIP_EXTERNAL = NO #SZIP_INCLUDE = #SZIP_LIB = # TIFF is required for the NDFileTIFF plugin. WITH_TIFF = YES TIFF_EXTERNAL = NO #TIFF_INCLUDE = #TIFF_LIB = # XML2 is required for ADCore so there is no WITH_XML2. XML2_EXTERNAL = NO #XML2_INCLUDE = #XML2_LIB = # ZLIB is required for the NDFileHDF5 and NDFileNexus plugins. # This may be optional in the future. WITH_ZLIB = NO ZLIB_EXTERNAL = NO #ZLIB_INCLUDE = #ZLIB_LIB = # ARAVIS is required for aravisGigE and ADAravis # Only available on Linux #ARAVIS_LIB = /usr/local/lib #ARAVIS_INCLUDE = /usr/local/include/aravis-0.8 # Location of GLIB include files and libraries. This is needed for aravis. # Our system has include files for glib-2.0 in 2 different places #GLIB_INCLUDE = /usr/include/glib-2.0 /usr/lib64/glib-2.0/include #glib-2.0_DIR = /usr/lib64 # The definitions above can be overridden in the following files. # The files are searched in this order, with the last definition being used. # CONFIG_SITE.local.$(OS_CLASS) # CONFIG_SITE.local.$(EPICS_HOST_ARCH) # CONFIG_SITE.local.$(EPICS_HOST_ARCH).$(T_A) Are there any libraries that ADPcoWin uses which I set to no? Thanks for the support! Michael ________________________________ Von: Sintschuk, Michael Gesendet: Mittwoch, 11. Dezember 2019 10:01:58 An: Mark Rivers Cc: [email protected]<mailto:[email protected]%3E Betreff: AW: pco Camera USB and IEEE interface Hey Mark, hey Diego, thanks for the help! I try the ADPcoWin driver. On github it says that the interface is CameraLink: https://github.com/areaDetector/ADPcoWin But if you say it works with any interface (what about IEEE only?), I will try it on a Windows7 64bit system. Michael ________________________________ Von: Mark Rivers <[email protected]<mailto:[email protected]%3E%3E Gesendet: Dienstag, 10. Dezember 2019 19:42:53 An: Sintschuk, Michael Cc: [email protected]<mailto:[email protected]%3E Betreff: Re: pco Camera USB and IEEE interface Another possibility is the ADPcoWin driver. This driver uses the PCO SDK so it should work with any camera interface, GigE or CameraLink. It only runs on Windows. Mark Sent from my iPhone On Dec 10, 2019, at 2:38 AM, Sintschuk, Michael via Tech-talk <[email protected]<mailto:[email protected]%3Cmailto:[email protected]%3cmailto:[email protected]%3E%3E%3E wrote: Hello, I have a pco.1600 camera with a USB/Ethernet interface and a pco.4000 camera with a IEEE interface. Is there a possibility for me to communicate with these cameras via an IOC? The AreaDetector Driver I found is intended for Cameralink-based communication: https://github.com/areaDetector/ADPCO Best regards Michael Sintschuk Michael Sintschuk Bundesanstalt f?r Materialforschung und -pr?fung (BAM) P: +49 30 8104-5736 (BESSY, Adlershof) P: +49 30 8104-4065 (BAM, Lichterfelde) [email protected]<mailto:[email protected]%3Cmailto:[email protected]%3cmailto:[email protected]%3E%3E -- This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
