Subject: PyDM setting alarm with PVView example
From: Rute Mendes via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 13 Mar 2020 19:05:26 +0000
Hello!
I've the latest version of PyDM installed and I was trying PVView for testing the possibility of using PyDM's EPICS CA aware widgets within a different application. Only that the following line doesn't work for me,
On pvview.py module,
widget.useAlarmState = True
I can only have the alarm  active when using PyDM launcher.
Am I missing something?
Do I have to follow the "note" requirements, referred on the link below, to use a PyDM widget on my code, by including PyDMApplication?
Thank you for attention.
I hope I can have your help.
Kind regards,
Rute
Re: PyDM setting alarm with PVView example Hugo Slepicka via Tech-talk
Prev: Huber SMC 9300 controller yangdl via Tech-talk
Next: Re: [EXTERNAL] vxW shell related Stefen Paul via Tech-talk
Prev: Re:RE: Huber SMC 9300 controller Dongliang via Tech-talk
Next: Re: PyDM setting alarm with PVView example Hugo Slepicka via Tech-talk
