1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: i400 electrometer stream device protocol [SEC=UNCLASSIFIED]
From: "CORNALL, Terry via Tech-talk" <[email protected]>
Date: Mon, 16 Mar 2020 02:08:52 +0000
Hi All.
I thought that there was EPICS community Streams support for the I400 electrometer made by Pyramid Technical Consultants (PCT) and distributed by FMBO
But I can’t find it now. I looked in github and on epics.anl
Anyone know if there a more modern version of the i400.protocol file out there than the one we have from 2006?
Part of the reason I ask is that in discussions with PCT I’ve discovered that their firmware might have changed since 2006 (!) and so the version of the I400.protocol we have might not work any more. Apparently the  ‘echo off’ command isn’t supported any more (for the last 10 years!)
Terry
Prev: Re: write to a single element of an array field Ralph Lange via Tech-talk
Next: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? Chiang, Liang-Chih [江良志] via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: PyDM setting alarm with PVView example Hugo Slepicka via Tech-talk
